![]() Drives: 2022 2LT RS Convertible Join Date: Apr 2021
Well after a long wait I got my Vert but the missed There Q.C. I got 2 red calipers and 2 silver. I also have bubbles on my satin black stripe. I was glad to get it after the time and waiting. But I really thing nobody is checking the cars going out the door. Now I have to wait to get the right parts in.
#2 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2023 Summit White Camaro ZL1 M6 Join Date: Dec 2021
2023 Dodge Durango SRT (daily driver) 2003 Nissan 350Z (modified) 2022 Rapid Blue 1SS 1LE M6 (delivered 2/19/22) (Sold) 2009 BMW 135i (Sold) |
Maybe the QA person is colorblind?
'22 2SS | Wild Cherry Tintcoat | Design Package 3 | NPP | MRC | A10 | NAV | Ceramic Coating | Full Frontal PPF | New Hood and Side Stripes | Michelin PS AS 4 | Range AFM Disabler
Mishimoto Catch Can | Diode Dynamics side markers | Cold Air Inductions CAI | LLoyd Velourtex front/trunk mats with Camaro SS logo | Footwell Lighting | Umbra Sequential LED Taillights ZL1addons Deluxe Rock Guards, Stealth Lift Pads, and Tow Hook | Escort MAXcam360c | Banks Data Pro and Pro gauges in ZZPerformance pillar pod | Paddle shifter extensions |
If you ordered a 2LT RS like it says below your avatar, then it's not supposed to have red rear calipers when you order the red caliper option. The red calipers are only for the FRONT on non-SS cars. What your car has is correct for an LT.
Bubbles are typical for winter installed vinyl. If they don't go away with warm weather or a heat gun, then it should be warrantied. |
Wow! Who at Chevy came up with that. Are the rear brakes single piston calipers on the LT?
Yes, I forget the exact details, but it is something related to parking brake differences on the LT vs SS trims.
2SS Convertible M6 NPP Riverside Blue w/ Silver Rally Stripes
Dec. 18: took her home Dec. 9: arrival at dealer Nov. 16-29: Toledo, OH (railyard) Nov. 9: 3800 -> 4300 (for stripes) Oct. 8: 3400 status TPW 10/25 Oct. 6: 3100 status TPW 10/25 Sept. 9: 3000 status TPW 10/4/2021 Sept. 3: 2000 status (after 5 1/2 months) Sept. 2: Change Order: 2SS (V6 constraint) April 12: Reordered as ‘22 3LT RS V6 (March 16:Initial Order ‘21 3LT RS V6) |
#7 |
In that case you would think the Dealer would know and explain to the OP that the set up is correct. Still seems to me to be an odd option.
#8 | |
#9 |
Don't know what to tell you. The order guide clearly states that it's for the front only. Even if you build it on Chevrolet.com it will show red on the front only. Sorry to be the bearer of bad news but none of the LT cars ordered with the $595 red caliper option have or will come with red on the rear.
#10 | |
Tampa Bay Camaros
Drives: 2017 Krypton Green 2SS Join Date: Jul 2011
Me and wife, in order
2011 2SS SGM 2013 2SS Hot wheels vert 2016 C7 DSOM 2012 2SS yellow vert 2017 2LT Krypton Green 2018 2LT Hot wheels crush 2020 2SS Shock vert. 2017 2SS Krypton Green coupe |
#11 |
Thanks guys I did have a long talk and your 100% right. I guess even reading print you miss thing. Sorry for my mistakes.
#12 |
Sorry you didn't get what you thought you were getting from the option. Still seems like to me its a strange set up with red calipers in the front and silver in the rear.
#13 | |
![]() Drives: 2016 1LT 'Vert Join Date: Feb 2022
The LT opgrade option that the OP ordered does include 4 piston Brembos, however they are not the same as the SS Brembos. They are a smaller version that use a 12.6" rotor (a different, thicker rotor than the base LT 12.6" rotor). The SS standard front rotor is 13.6" diameter with a beefier 4 piston caliper. The LT's Brembo caliper design is common with the Cadillac ATS, and I presume it is intended to have desired clearance to smaller wheels offered on LTs and ATSs that aren't available on SSs. I'd look into a caliper paint kit if you want the rears to match. |
#14 |
![]() Drives: 19 ZR1 20 350R Wife -> 24 ZL1 Vert Join Date: Nov 2016
Amazing
Red on one side and silver on the other or was it front and rear? D. |
