Old 03-04-2022, 06:22 AM   #1
LT1ornothing
Drives: 2020 LT1 M6
E85 vs 93 2022 Q2
So I have been noticing that as fuel prices increase, so has the gap between a gallon of e85 and 93. Currently in my area, e85 is nearly a $1.25 cheaper than 93. Near empty, the cost difference between fill ups is over $15 and climbing. My camaro is not my daily and has about 2 years of warranty left. I understand my fuel economy will decrease and I will see a small gain in power.
Has anyone else switched or seriously considering switching? I understand several of you do not have e85 available close by, I would like to hear from people like myself who have e85 available nearby. Thank you.
Old 03-04-2022, 07:40 AM   #2
laynlo15
Drives: 2022 Lt1 A10
I just switched my 2022 Camaro Lt1, love it and year here in Missouri its about $1.00 cheaper which is still a big savings. I was getting about 27 mpg on the highway on 93 octane and I get about 23-24 now in normal driving. Combined around 20 mpg city and hwy. I'm happy with that. I had converted my 2016 C7 Corvette that I sold in December and it was about the same mileage difference. I bought E85 for the Camaro the first of last week and it was 2.69 per gallon, not sure what it is today but guessing over 3.00 and I'm also guessing 91 octane is 4.00 to 4.25. I run 87 octane in my 6.2 Silverado unless I'm towing and it was 3.26 per gallon 2 days ago. My opinion is its well worth the switch.
Old 03-04-2022, 07:50 AM   #3
cjperformance
cjperformance's Avatar
I agree. Id go full e85 if my fuel system supported it, but ive been blending 50/50. Havent filled up in a month or two but e85 was about $1 cheaper. You get about 70-75% of your MPG on e85 compared to 93 so not sure there is any real savings, but i do it for the octane and performance improvements, which for forced induction are huge.
It burns more clean smelling, even blended, so thats a side effect bonus. Smells like burnt hand sanitizer on cold starts
Only downside is it can be harsher on eng components than gasoline. So far havent seen any camaro owners with e85 fuel related issues. As long as you change oil at suggested intervals, and dont let the fuel system sit idle with e85 for months on end you'll prob be fine.
DSX Aux Low Side | LT4 high side | Flex Fuel
TooHighPsi Port Injection (installed & tuning)
CircleD 3K Stall | QA1 CF Driveshaft
Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear
Forgestar F14 18x8 NT555G2 235/50/18 Front
10.84@131 w/4.13" pulley
??.??@??? w/3.7" pulley (installed & tuning)
Old 03-04-2022, 07:54 AM   #4
laynlo15
Probably not as bad here in Missouri since our stations only blend at about E65 so still plenty of gasoline in the mix. One thing about E85 and tuning if properly is if you live in a cold climate area you can still revert back to regular gasoline because the sensor will see its not E85 and not add any additional timing as it does with E85 so your good to go.
Old 03-04-2022, 09:41 AM   #5
Jaxcam02
Jaxcam02's Avatar
Drives: 2017 Silverado/2017 ZL1
Lucky, e85 in Florida is just as expensive as regular and midgrade. It was $2 a gallon in November. Now the last I saw it was 3.50+. I have only gotten to enjoy one fill up using e85 since my tune because the 30% rule doesn't financially make sense here.
Jaxcam02 is offline   Reply With Quote
Old 03-04-2022, 09:48 AM   #6
FlukeSS
FlukeSS's Avatar
Drives: 2020 Camaro 2SS A10
I drive my car daily at least this winter. 150-200 miles/day for work.
While I would like to pay E85 prices, I also know E85 is harder on the car especially in colder winter climates.
So, as much as I hate the price of 93. I'll be sticking with 93 until weather breaks finally.
Old 03-04-2022, 09:56 AM   #7
Jaxcam02
Jaxcam02's Avatar
One thing to think of that I missed, once you go on an e85 tune and install an e85 sensor, you can kiss that warranty goodbye.
Old 03-04-2022, 10:00 AM   #8
FlukeSS
FlukeSS's Avatar
Only the power train warranty.
The warranty still covers other aspects. Electrical/Suspension, etc. At least my warranty does. But I did my conversion at 36k miles which is when the power train warranty expired. Yes I have the extended warranty but I told myself I wasn't going to do this if all I was concerned about was reselling the car or was worried about the engine failing.
If it happens it happens. I'll deal with it. But my warranty still covers everything else that is stock.
Old 03-04-2022, 10:43 AM   #9
TP2SS
TP2SS's Avatar
Drives: 2016 2SS Convertible
The bumper-to-bumper is 3 years/36,000 miles.
The powertrain is 5 years/60,000 miles.
Hyper Blue/Ash Gray
A8
Magnetic Ride Control
Dual Mode Exhaust
2019+ version Split Spoke Silver Wheels
Navigation
Silver Rally Stripes
TP2SS is offline   Reply With Quote
Old 03-04-2022, 10:43 AM   #10
laynlo15
Warranty is an issue for some so I can understand that cause once you break into the ECU you can put it back to stock tune but GM will catch it if they want to. Since I have HP tuners I'd put it back if something did happen but doubt they'd warranty any power train as stated above. I noticed when I dropped my truck off this morning for Oil change, rotation and alignment on my 2021 Silverado, the station across the street was $3.15 for E85, still cheaper here then Premium fuel.
Old 03-04-2022, 10:55 AM   #11
s346k
s346k's Avatar
Drives: like an old lady
i didn’t know anyone actually paid attention to the cost difference of ethanol vs gasoline. i exclusively run e85 when i can reasonably drive the car. typically april-november. i haven’t looked at gas or e85 prices here. from the sounds of it, i will be less than thrilled. i think i recall e85 being $1-1.25 cheaper than premium. i may look around tomorrow if this pile will start up. haven’t touched it in quite a while.
Old 03-04-2022, 11:31 AM   #12
LT1ornothing
Drives: 2020 LT1 M6
I've been looking at prices of both since gasoline bottomed out in 2020 when I bought my car. 93 was under $2.00/gal back then. Went from just a few cents difference for e85, to about $1.25 right now in the 2nd qtr of 2022. If this trend continues, the difference between e85 and 93 will be over $1.50 soon in my area. Crunching some numbers, I would be saving money switching to e85 even after accounting for the lowered range of e85 at this moment.
If I can find some cheap catless longtubes, I believe I will flex fuel and tune this spring. I need longtubes for my build anyway. I have a new blower kit sitting here waiting for a fuel system upgrade to hopefully install later this year.
Old 03-04-2022, 12:02 PM   #13
FlukeSS
FlukeSS's Avatar
Then I got it reversed.
Either way like I said. I bit the bullet took a chance. If something happens it happens.
But I'm at 43k now. And I just had the car in the shop recently for inspection. Hit a pothole and was worried I may have damaged something on the suspension.
They said everything is good on the car. Even more so the exhaust. They said whoever did the exhaust did a great job on my car.
Old 03-04-2022, 12:10 PM   #14
TP2SS
TP2SS's Avatar
Where in MI are you? Who did your e85 tune? I thought about doing the conversion when I first got my car (2019) but the PW was still valid so I didn't. It's expired now so it may be worth it now. I've seen the kits online and I'm sure I can do the mod DIY, but have no clue where to get the tune.
Any other mods you had to do for e85 other than the kit that is sold?
Hyper Blue/Ash Gray
A8
Dual Mode Exhaust
Navigation
