Lamude Racing Engines
Drives: 2018 ZL1 Hyper Blue Jennetty tuned Join Date: Feb 2022
hood insert
Anyone had the carbon fibre hood insert out,tried removing mine but it seems like its either bonded or glued in?
![]() ![]() ![]() Drives: 2018 ZL-1 Join Date: Jan 2018
It has double sided tape on the rear edges. You have to peel it back carefully
![]() ![]() ![]() ![]() Drives: 2019 ZL-1, Shadow Gray, Sold Join Date: Jan 2019
There is also 3 clips on the side closest to the Windshield, along with the double-sided spongy tape. Left/Right and middle. When I reinstalled, I replaced the double-sided tape, but did not pull the covering off of the side that rests against the insert. Makes it easier to remove again, if you have too. IMHO the clips will hold the insert in place. I think GM used the tape as a cushion, rather than an adhesive. I would suggest not to try and remove this in the cold weather, the clips are plastic and could become very brittle.
Here is a link to some great pics of the clips and spongy tape. https://www.camaro6.com/forums/showt...+center+insert |
Dyno Show Queen LOL
heat gun helps a lot w the tape.
ZL1 Driver
Drives: Camaro ZL1 & BMW M3/E92 Join Date: May 2009
Use fishing line and slowly run it behind the hood scope. That will help separate it without body damage. Wear good gloves so that the line does cut your fingers.
Thanks for the detailed info guys,perfect!, i know this may sound odd,but the reason for removal,is it just looks black to me,cant really tell its carbon fibre,so im gonna wrap it in 3M Di Noc carbon black wrap.so it actually looks like it should in my opinion.thoughts?
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
They are all carbon fiber. So you'll be wrapping a carbon fiber piece. They are separated as to be exposed and to be painted after manufacture. The exposed are hand selected to have the most perfect straightest weave then clear coated. These are the ones installed as a $600 option. The not so perfect ones are painted and installed as std equipment. Same process they did on the 5th gens
#8 | |
#9 |
![]() ![]() ![]() Drives: 2018 ZL1 Camaro 6M Red Hot Join Date: Aug 2013
Interested to see how well the wrap goes. Can you post pics when you are done?
I too have the black painted insert and wish it were exposed carbon. The weird thing is that I didn't order my ZL1, I bought it off a dealer lot and it came with the carbon fiber dash on the passenger side. Seems stupid to me that the dealer ordered the optional CF dash, but didn't get the exposed CF hood insert to match.
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
#10 | |
#11 |
https://www.camaro6.com/forums/attac...1&d=1647368169
Well pleased with the result. Best to use a 3m 1080 or 2080 carbon wrap. |
#12 | |
#13 | |
#14 | |
