Old 02-28-2022, 01:42 PM   #1
Drnick
Drives: 22’ ZL1
Cool Cat back exhaust for a convertible??
Borla ,magnaflow, and others only make axle back exhaust system
Has anyone with a vert, installed a cat back on
The 6th gen? I know there’s cross bracing that
Will interfere with 3” pipes, and oem pipes are actually
Flattened were they intersect with bracing.
Drnick is offline   Reply With Quote
Old 02-28-2022, 04:43 PM   #2
willzilla
D3RPZILLA
willzilla's Avatar
Drives: 2021 Camaro ZL1 a10
Maybe buy the regular cat back, take some measurements, and have a shop crush the piece in the same spots lol.
Sent from my SM-G998U using Tapatalk
Website: z1lla.com | YouTube: sub.z1lla.com | Merch: Shop & Etsy
YouTube Playlists: Performance Mods | Show Mods | Other Mods
willzilla is offline   Reply With Quote
Old 03-01-2022, 11:56 AM   #3
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
I have not seen any catbacks for the Camaro, they all say "not for convertible".
Not sure on your goals, but some modding as mentioned above may be the easiest option.
If it were me, I would just get an axle-back. Not sure the catback is worth the extra coin.
J-Rod Built and Matt@FSP Tuned
ST1LE is offline   Reply With Quote
Old 03-02-2022, 07:25 PM   #4
Drnick
Drives: 22’ ZL1
I’ve been under car, I don’t see why borla/magnaflow, or others
Can’t make a catback, there is only one issue with a vert, and that’s
The crimping/ flattened part at the rear, to make it fit under the
Frame stiffening struts, they could do the same with there 3” piping.
Old 03-19-2022, 07:55 AM   #5
Noahszl1
Drives: 2021 Camaro Zl1 connv
Do not crush the exhaust, i installed a borla atak cat back on my 2021 convertable. It will fit ,only issue if you hit a bump you will hear it knock the cross member. Still worth it i find.
Noahszl1 is offline   Reply With Quote
Old 03-19-2022, 11:26 AM   #6
Drnick
Drives: 22’ ZL1
Noah, thx for info , I’m assuming the exhaust pipe goes
Over that structural frame crossover, just as in oem
Configuration, how much clearance between actual
Exhaust pipe and structural frame crossover?, and did
U have any other issues with install? Thx
