Old 02-23-2022, 03:11 PM   #1
FlukeSS
FlukeSS's Avatar
Drives: 2020 Camaro 2SS A10
Hit a pothole yesterday...
Little worried.
I hear a thumping or bumping sound as if someone was tapping their knuckle on the inside of the front left wheel well. Also with the driver side window slightly down I hear a ticking noise as if a rock is stuck in tread (which is what I thought it was) But the sound is best described as a suction cup being pulled off a window in rapid succession. More of a Tick + Pop noise
I saw no visible damage on the tire/rim or the wheel well.
The noise is pretty noticeable at lower speeds 30-40 mph and at 80 the tempo of the noise is fast enough to seem fluent and not an issue presently.
I can however tell it is related to the wheel turning.
When I apply brakes from 80mph to a slow down the sound gets louder and the tempo slows down all the way down to 30mph where the sound is at its normal volume.
I'm thinking about taking the car in to see if there is any damage to the front suspension/wheel well/brakes.
Even though my car is modded, warranty/insurance should cover that I believe yes? Since its not related to the engine/exhaust?
Old 02-23-2022, 03:17 PM   #2
Jaxcam02
Jaxcam02's Avatar
Drives: 2017 Silverado/2017 ZL1
I do not believe warranty will cover any obvious impact damage. My advice would be to lift the car, get the wheel off and inspect the wheel and the suspension for any obvious damage or foreign object lodged in there.
Jaxcam02 is offline   Reply With Quote
Old 02-23-2022, 03:19 PM   #3
FlukeSS
FlukeSS's Avatar
Sorry I edited my post to include Insurance covering it if need be.
Old 02-23-2022, 03:30 PM   #4
Sweptwing
Sweptwing's Avatar
Drives: 2017 2LT RS V6 M/T
Could be a possible tire cord shift and or a broken ruptured belt. From now till May we’re playin chicken with potholes. “Michigan Roads”
Be safe!
Sweptwing is offline   Reply With Quote
Old 02-23-2022, 04:08 PM   #5
TP2SS
TP2SS's Avatar
Drives: 2016 2SS Convertible
Be safe!
Luckily I'm playing chicken with my XT5 and its giant 235/65R-18s and the SS is safely ensconced indoors and blocked by boats that aren't moving until April to keep me from getting anxious and doing something stupid early! Doesn't help it was 55 here yesterday in the Motor City and 25 today! There's definitely some car-swallowers out there
Hyper Blue/Ash Gray
A8
Magnetic Ride Control
Dual Mode Exhaust
2019+ version Split Spoke Silver Wheels
Navigation
Silver Rally Stripes
TP2SS is offline   Reply With Quote
Old 02-23-2022, 04:49 PM   #6
Azerlazer26
Azerlazer26's Avatar
Drives: 2018 Camaro 2SS
Lemme guess… you from southeast Michigan also? I swear to god it’s a literal war zone with the potholes this year man smh… sorry to hear about everything but do stay safe out on the roads.
Azerlazer26 is offline   Reply With Quote
Old 02-23-2022, 06:46 PM   #7
So sorry to hear this
Wonder what would happen if 1) NE roads had a proper substructure, 2) pavers used high quality asphalt and 3) cities and townships used something other than mounds and mounds of corrosive salt and brine as friction enhancement (say, sand)... "but this is their job security", I hear you say—well, they could also build new roads or widen existing ones, because there are more cars and trucks driving on them... even repaving without massive potholes would be quite realistic, given how much heavier the average car/truck must be than 10-20 years ago, and EVs are making it even worse.
Old 02-24-2022, 09:27 AM   #8
ember1205
Hot Camaro
ember1205's Avatar
I suspect that the "proper substructure" you're referring to would be to dig down 48" plus and install solid materials that are impervious to freezing - think "basement" for a house in areas where the ground freezes. The cost of that would be outrageous...
Even then, I doubt it would be perfect. You'd effectively have been able to completely remove the cause of "frost heaves" which bend and break the road surface when water underneath freezes, but water could still penetrate the road surface through damage and wear areas and the effect would be the same.
What we would need would be a multi-layer roadway with a grated top surface that allows everything fall through (like a bridge's road deck) and onto a lower surface where it could drain away. In cold climates, the lower surface would need to be somehow heated so that snow could melt before running down into storm drains.
Old 02-24-2022, 09:56 AM   #9
Yes, it would be prohibitive, that's not what I had in mind, but simply materials that don't exhibit cracks so severe that they turn into 5-inch potholes. Maybe something that has more flexibility to accommodate periodic expansion and contraction. I'm also positive that excessive salting contributes to the problem, plus it destroys cars, as we have all seen in the northeast.
That grated top surface of yours would have much less traction (boo) and it would be extremely noisy, plus heating the lower surface is just not feasible for millions of miles of roadway.
More plowing, sand instead of salt, and proof of winter driving ability as part of license requirements, those would be my final suggestions
Old 02-24-2022, 10:14 AM   #10
ember1205
Hot Camaro
ember1205's Avatar
No doubt salt is part of the problem - is corrosive and destructive to the road surfaces in a variety of ways. You can't use it al all on cement as it will cause the materials to flake away (just part of the reason that cement is only used in areas that don't freeze).
Old 02-24-2022, 01:25 PM   #11
FlukeSS
FlukeSS's Avatar
Right Front Tire 35psi - 0psi flat while driving on the highway. No tire damage, got car towed as an excuse to have them do a mechanical inspection in addition to fixing/replacing tire.
Old 02-24-2022, 01:26 PM   #12
FlukeSS
FlukeSS's Avatar
I work in Ann Arbor. Was driving on Washtenaw Ave. Which is ef'ing bad at 23 and Washtenaw Ave.
But I live in Lansing, moving to Novi soon.
Worst part is I work for Washtenaw County. Don't blame me for the roads! Not my ef'ing job!
Old 02-24-2022, 01:53 PM   #13
m6-lt1
m6-lt1's Avatar
Drives: 2012 Shelby GT500
Check the top of the strut tower for damage. I’ve seen a few more posts than I’d like to see on these boards where people hit large pot holes that caused small cracks on the top of the strut tower. If you see one, you’ll definitely want to call your insurance.
m6-lt1 is offline   Reply With Quote
Old 02-24-2022, 02:23 PM   #14
Azerlazer26
Not the one to point fingers but they really need to get working on these potholes soon. Novi/northville have been messy. I heard it’s even worse out on the east side!
More importantly, when you do move over to Novi hit me up!!! I need more camaro guys to drive with lol
