Old 02-20-2022, 11:50 PM   #1
collinms
Drives: 2017 ZL1 A10 Summit White
Battery charger
I have a 2017 ZL1 and bought a battery charger. Do I connect it straight to the battery in the trunk or use the jumper posts under the hood I see in the manual? Thank you
collinms is offline   Reply With Quote
Old 02-21-2022, 09:16 AM   #2
joekd
Drives: 2018 Camaro SS vert
Trickle charger I assume? If so it really does not matter where you hook it up
joekd is offline   Reply With Quote
Old 02-21-2022, 09:48 AM   #3
Use the battery in the trunk directly if you want to set up a permanent connection with a plug, otherwise you can safely just use the underhood terminals for the occasional hookup. I do the latter.
Old 02-21-2022, 10:55 AM   #4
collinms
Thank you both. This helps.
Old 02-21-2022, 11:37 AM   #5
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
For a coupe, underhood is much easier. No fiddling with paneling required.
Old 02-21-2022, 12:19 PM   #6
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
Drives: 2018 ZL1 1LE
I have a permanent connection from under the hood with an extended cord snaked so that I can plug it in thru the front without having to open and close the hood.
Old 03-02-2022, 05:17 AM   #7
Wuiquen
Wuiquen's Avatar
Drives: 2018 Hot Red ZL1
Can you post some pics of your set up? I am just scared that if my trunk isnt open, i will forget to disconnect and drive off.
Old 03-02-2022, 08:12 AM   #8
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
Pics are nearly impossible since it’s hidden with the exception of the connection under the hood and it exiting thru the front. Don’t be concerned about forgetting to disconnect it and driving off other than the embarrassment from showing up with the chord dangling from your front end.
Old 03-02-2022, 12:58 PM   #9
joekd
I connected my charger leads to the battery then ran the cord through a small hole I made in the panel, this way I can pull it out when using charger and push it back in so only the cover shows when not in use
Old 03-15-2022, 09:44 PM   #10
JSH
JSH's Avatar
Drives: '20 ZLE
Came back from vacation and it was deader than dead. Nothing worked, zero, nada. Put on trickle charge for 20 hours using Chevy's OEM charger, which had zero effect on the battery (Antigravity) charge, with the leads hooked-up to the posts under hoop. Put a regular 12v charger on it for a few hours ... vroom
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO.
15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR.
100 octane: 1045hp/1055tq.
100 octane + Alky MAF Meth (1) 10+:
Old 03-16-2022, 09:37 AM   #11
joekd
A 1-2 Amp Trickle charger will up to 48 hours to charge up a dead battery
Last time mine was dead (because I forgot to hook up the trickle charger and had a bunch of lighting left on) I started the car with a jump pack, drove it for a good 30+ minutes then came home and hooked up the trickle charger
Old 03-16-2022, 09:43 AM   #12
JSH
JSH's Avatar
Drives: '20 ZLE
I left my laptop, with lid closed, plugged into OBDII as I always do, never thinking that it would suck ALL the power from my car battery. Lesson learned.
Now that it starts, I'll leave it on 2-amp charge for a day or so.
2020 ZL1LE A10.
