Old 02-20-2022, 02:28 PM   #1
asthmamax11
asthmamax11's Avatar
Random codes CEL P18C4 & U0401-71
Was driving and CEL turns on
Rev match feature doesn't turn on
Rear camera doesn't turn on
P18C4 gear position sensor low voltage
U0401-71 anti-lock brakes
Car is 6 speed with 38k miles
Magnuson supercharged for over 10k miles no issues
Anyone else have experience with these codes ?
16 1SS M6 White
Magnuson 2.3 Heartbeat
Roto Fab
Hurst short shifter
#'s coming soon
Riaction coilovers
1LE sway bars
BMR mm
BMR chassis brace
02 Z28 M6 35th anniversary
80k miles
T-tops
Leather
Bolt ons
Daily Driver
Old 02-20-2022, 02:39 PM   #2
Weak battery perhaps? These issues are unrelated, and the codes popping up at the same time indicate a potential electrical problem, so the first thing I'd check on the cheap would be the battery.
Old 02-20-2022, 10:01 PM   #3
asthmamax11
Well I replaced the battery about 8 months ago
I don't drive the car more than about three times a month though
I'll get it tested my next day off
16 1SS M6 White
Roto Fab
Hurst short shifter
#'s coming soon
Riaction coilovers
1LE sway bars
BMR mm
BMR chassis brace
80k miles
T-tops
Leather
Bolt ons
Daily Driver
Old 02-20-2022, 10:18 PM   #4
SSgtSS1LE
SSgtSS1LE's Avatar
Drives: 2017 Camaro SS 1LE
Gear Position Sensor Circuit Invalid Data
Check the wiring harness for short to ground between sensor and ECM. Both codes should clear, not return, and current gear should display once short is repaired.
DTC Descriptor: Invalid Data Received From ECM
DTC: U0401
Some devices are constantly receiving information from other devices through serial data communication network. The invalid data code will be set when a receiving device detects a discrepancy in information it receives from another device causing its integrity to be questioned. The symptom byte listed in the DTC Descriptor is for engineering reference only. No external circuit diagnosis is involved.
Symptom Byte: 71
Invalid Data - This sub type is used by the Electronic Control Unit to indicate a signal was received with the corresponding validity bit equal to invalid or post processing of the signal determines it is invalid.
Circuit: Gate Select Position (Gear Position Sensor, number 3)
DTC: P18C4 - Short to Ground
Name:  Gear Position Sensor.PNG
Circuit/System Description
The gate select position sensor is a switching transistor mounted to the transmission extension housing. The four wire sensor interfaces directly with the Engine Control Module (ECM). The ECM supplies 5 volts to the Gate Select Position sensor on a 5 volt reference circuit and also provides a ground path on a low reference circuit. The sensor provides a Pulse Width Modulated (PWW) duty cycle to the ECM on two signal circuits that are proportional to the linear and radial position of the corresponding magnet assembly mounted to the shift shaft. The vehicle uses the gear position sensor information primarily for Active Rev Matching and Active Fuel Management. The ECM monitors the radial position signal 1 circuit for low and high voltage conditions.
Name:  Gear Position Sensor Circuit.jpg
SSgtSS1LE is offline   Reply With Quote
Old 02-21-2022, 08:51 PM   #5
asthmamax11
Thank you for detailed diagram and highlighting the two culprits.
I appreciate you taking time to help.
16 1SS M6 White
Roto Fab
Hurst short shifter
#'s coming soon
Riaction coilovers
1LE sway bars
BMR mm
BMR chassis brace
80k miles
T-tops
Leather
Bolt ons
Daily Driver
Old 03-25-2023, 07:49 PM   #6
Ruthless Camaro
Drives: Chevrolet Camaro 2SS
I just bought a 2017 2SS M6 and I’ve only had it for 2 days until my check engine light came on along with the service parking break, I also noticed my rev match, reverse camera, cruise control, blind spot monitoring, drive modes, and my exhaust sound selector was not working, I took it to autozone for a scan and these codes popped up, P0735, incorrect 5th gear ratio, Secondary DTCs
•P0734: 4th gear ratio incorrect
•P18C6: Gear position sensor circuit 2 low voltage.
-U0401-71: invalid data received from engine control module-invalid data
So I took it chevy and it looks like the gear selector position sensor needed replacement, good thing I didn’t have to pay for it cause it was covered, but the service advisor said it was $1400, still waiting for the part and my car is still at the service. Did you ever get this issue solved?
Ruthless Camaro is offline   Reply With Quote
Old 01-05-2024, 06:47 PM   #7
Summit20171SS
Summit20171SS's Avatar
Drives: 2017 1SS M6
Im having this same issue with codes P0735 and P0729 which is 5th and 6th gear
2017 1SS M6
~ Air Raid Cold Air Intake~ ~ 3" Corsa Extreme Catback Exhaust ~
Summit20171SS is offline   Reply With Quote
Old 10-12-2024, 01:49 PM   #8
Xyphos
Xyphos's Avatar
Drives: 2023 LT1 Vivid Orange
My ‘23 just started having the same codes. P18c4 and P0729 and P0735. Is it just a bad sensor or could it be something else causing the malfunction (driving habits, road conditions, etc)?
Xyphos is offline   Reply With Quote
Old 10-13-2024, 08:37 AM   #9
ctrlz
Sheesh! This part is less than $300 and a simple 4 bolt install.
I'm not sure this is the exact part number, but I have found it before and price is similar. There is a magnet attached to a gear selector arm inside the tranny, and this sensor detects the position of the magnet to report which gear you are in. It is located back right side of tranny.
https://parts.gmparts.com/product/gm...GSIfgBOchB6Clc
