Old 02-20-2022, 10:42 AM   #1
TKuipers
Drives: 2016 Chevrolet Camaro 2SS 6sp
2016 2ss 6sp salvage title Frankenstein fix
Hello
Just bought my first Camaro. It does have a salvage title because of a passenger front fender bender. The guy I bought it from was a second hand owner and didn't know much about the repairs. It runs and drives great! I'm not getting any codes or anything. I had my head under the hood looking around and I saw some electrical tape bundles and explored further and found this hacked "fix".Name:  IMG_0936.jpg
It looks like a relay switch and something else (I have no clue ) attached.
The wires run down the side of the radiator which I don't think is the correct location. If I followed it correctly, one goes to the magnetic ride control sensor and I'm not sure from there.
Any help in figuring out what this is would be very helpful. Thanks guys
TKuipers is offline   Reply With Quote
Old 02-20-2022, 11:02 AM   #2
TP2SS
TP2SS's Avatar
Drives: 2016 2SS Convertible
My guess is someone tried to bypass/tinker-with/sharpshoot/jury-rig this system, if the '16 SS even has it (?)
The original thread is here https://www.camaro6.com/forums/showt...=506628&page=2 and this came from the last post which was just a week ago or so. There's some handy diagrams attached to the post too.
Originally Posted by JD64 View Post
My 2019 ZL1 has them, here are the calibration procedure and sensor replacement for the front and rear.
2019 Chevrolet Camaro V8-6.2L SC
Suspension Position Sensor Calibration
Vehicle Sensors and Switches Sensors and Switches - Lighting and Horns Headlamp Alignment Sensor Testing and Inspection Programming and Relearning Suspension Position Sensor Calibration
SUSPENSION POSITION SENSOR CALIBRATION
Document ID: 4310963
Calibration Criteria
Note: Remove any excess weight and do not sit in the vehicle during the headlamp leveling sensor learn procedure. Any additional weight will cause the calibration of the front and rear suspension position sensors to be inaccurate and affect the operation of the headlamp leveling system.
The headlamp leveling sensor learn procedure must be performed after a suspension position sensor has been removed/reinstalled/replaced, or if the headlamp leveling control module has been serviced. The learn procedure will set the front and rear suspension position sensors home value. This value is used by the headlamp leveling control module to determine the movement of the front and rear suspension systems. The headlamp leveling control module compares the information from both suspension position sensors and adjusts the headlamp leveling as needed.
Calibration Procedure
Ignition ON/vehicle in Service Mode.
Install a scan tool.
Navigate to the Configuration/Reset Functions menu of the Headlamp Control Module.
Select Configuration/Reset Functions.
Select Headlamp Leveling Sensor Learn procedure and follow the directions displayed on the screen.
Front Suspension Automatic Forward Lighting Position Sensor Replacement
Vehicle Sensors and Switches Sensors and Switches - Lighting and Horns Headlamp Alignment Sensor Service and Repair Removal and Replacement Front Suspension Automatic Forward Lighting Position Sensor Replacement
FRONT SUSPENSION AUTOMATIC FORWARD LIGHTING POSITION SENSOR REPLACEMENT
Document ID: 4176347
Callout Component Name
Preliminary Procedure
Front Wheelhouse Splash Shield Replacement
1 Front Suspension Automatic Forward Lighting Position Sensor Nut
Caution: Refer to Fastener Caution.
12 Nm (106 lb in)
2 Front Suspension Automatic Forward Lighting Position Sensor
Procedure
Disconnect the electrical connector.
Using an appropriate tool, separate the ball and socket.
Rear
Rear Suspension Automatic Forward Lighting Leveling Position Sensor Replacement
Vehicle Sensors and Switches Sensors and Switches - Lighting and Horns Headlamp Alignment Sensor Service and Repair Removal and Replacement Rear Suspension Automatic Forward Lighting Leveling Position Sensor Replacement
REAR SUSPENSION AUTOMATIC FORWARD LIGHTING LEVELING POSITION SENSOR REPLACEMENT
Document ID: 4176326
Rear Suspension Lower Control Arm Cover Replacement
1 Rear Suspension Automatic Forward Lighting Leveling Position Sensor Nut
12 Nm (106 lb in)
2 Rear Suspension Automatic Forward Lighting Leveling Position Sensor
Procedure
Using a hammer, gently tap on the sensor stud to disengage the splines on the stud.
Remove the rear suspension automatic forward lighting leveling position sensor from the keyhole slot.
Hyper Blue/Ash Gray
A8
Magnetic Ride Control
Dual Mode Exhaust
2019+ version Split Spoke Silver Wheels
Navigation
Silver Rally Stripes
TP2SS is offline   Reply With Quote
Old 02-20-2022, 02:23 PM   #3
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
Those wires and relay need to be covered insulated better. Thats an underhood fire waitin to happen.
Old 02-23-2022, 10:03 AM   #4
TKuipers
I'm thinking it might be an engine cooling fan resistor? What do you think?Name:  Screen Shot 2022-02-23 at 7.56.06 AM.png
Old 02-23-2022, 01:38 PM   #5
95 imp
Dumb Ass Deluxe
Just duct tape it and you'll be fine.
Old 02-23-2022, 02:48 PM   #6
mRahmani
Drives: ‘23 SS 1LE
Can you peel back the wrap on the harness side a bit to see what color the wires are? Would also be good to know if there’s any wires tucked in there that they didn’t bother connecting.
Right front position sensor should have 3 wires: yellow/white, black/gray, and brown/red.
RF strut actuator should have 2 wires: brown and black/white.
2023 2SS 1LE “Red Hot”
Built 7/14/22
Delivered 8/27/22!
mRahmani is offline   Reply With Quote
