02-17-2022, 04:58 PM | #1 |
Silverbullet
Drives: 2010 SIM 2SS/RS LS3 Join Date: Feb 2014
Headlights/RS Package Help!
I tried to find my exact problem on here but couldn’t seem to find anything.
I have a 2010 2SS with the RS package. When using the fob to unlock my car the passenger headlight won’t come on (halo is fine). When I get in and start the car and the auto lights come on, I have the same issue. Driver side headlight and halo work with no flaws. If I flip my switch a few times, then the light works on the passenger side. Obviously, the light isn’t burnt out like I had originally thought since flipping the switch works. What would cause just the headlight (not halo) to not automatically come on or even manually unless I flip the switch a few times? It’s a pain in my ass when driving at night, I always have to get out and check to make sure both are on before going anywhere lol. Also, for those that have replaced headlight bulbs what brand, store, part number, etc. do you recommend getting them from?
Mods:
Cold Air Inductions Cold Air Intake - Window Tint (15% Ceramic) - Muffler Delete w/Stock Tips - MRR ZL1 Replica Wheels (20x10 +23 front-20x11 +43 rear) - Toyo Proxes ST III Tires (275/40/20 front-315/35/20 rear) |
02-17-2022, 05:36 PM | #2 |
Drives: 2010 SS Join Date: May 2014
Sounds like you might have a bad ballast on that side.
02-17-2022, 07:37 PM | #3 |
Drives: 2015 Z/22 Join Date: Aug 2015
I bought these to replace: https://www.amazon.ca/Philips-Automo...ve%2C80&sr=1-3
Philips, 4300K, D3S, 35 watt. Believe this is the factory/OEM bulb, or same thing. Not cheap at $75 (CAD) per bulb, but my dealer wanted $300 + tax per bulb Regarding the issue, guess for starters make sure the bulb is connected properly/securely as well as any connectors on the light/ballast.
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
02-17-2022, 08:14 PM | #4 |
Drives: 2014 1ss camaro Join Date: Jul 2017
yes, just as killboy said check your connections first. while you're at it smear a little silicone grease on the connections limits oxidation and repels water.
02-18-2022, 06:54 AM | #5 |
Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3 Join Date: Dec 2021
02-20-2022, 09:36 PM | #6 |
Silverbullet
Thank you guys!! I was kind of thinking the same, but wasn’t sure. I’ll check the connections. If that’s good then I’ll look into a new ballast and hope my husband can replace it soon. Working a lot of hours and rarely home when I’m home with the car lol.
Mods:
