Old 02-16-2022, 05:52 PM   #1
itznickyjay
itznickyjay's Avatar
Drives: 2020 RS
LED foot lighting help needed
Hello I am trying to hardwire these new LED strips I just purchased.
I know I have a fuse box in the rear as well as up front. I am most likely going to tap into the rear fuse box because I don't want to have to mess with my firewall. nor do I know how to wire through a firewall.
So I'm going to be using my rear fuse box. Which fuse should I tap into?
I see a dedicated slot for RGB lights, but there is not a fuse in there currently. So an add a fuse you need an existing fuse in its slot I believe. Can anybody help me out?
itznickyjay is offline   Reply With Quote
Old 02-16-2022, 05:54 PM   #2
itznickyjay
Drives: 2020 RS
Old 02-16-2022, 05:55 PM   #3
itznickyjay
Drives: 2020 RS
https://imgur.com/a/XrRgnTy
Old 02-16-2022, 06:58 PM   #4
Trochoidal
Drives: 2017 Camaro 2SS A8
Ive never done this install, but this might be an option instead of coming from the rear fuse box.
https://www.camaro6.com/forums/attac...0&d=1623542539
Here’s the entire thread:
https://www.camaro6.com/forums/showthread.php?t=501526
Old 02-17-2022, 07:45 AM   #5
cheeze9878
cheeze9878's Avatar
Drives: 17 camaro ss
Not 100% sure what you're asking. So I will go with what I think.
To wire it up to the fuse box in the back all you need to do is install a fuse ( check what amps your lights will be pulling to figure out what size fuse you need) and wire into the box on the rear side if the fuse ( or you can rig it in the front side but will look crappy and cheap.) You will also need to correctly ground the lights to the body. Then depending on how they are turned on you may need a switch. ALSO Make sure you run the wire to the correct side of the fuse!!
cheeze9878 is offline   Reply With Quote
Old 02-17-2022, 04:31 PM   #6
itznickyjay
Drives: 2020 RS
So I don't have to use an add-a-fuse?
Or can I use my add-a-fuse for my wiring and run it into an empty fuse slot?
Old 02-18-2022, 01:07 PM   #7
cheeze9878
cheeze9878's Avatar
Yes you can use the add a fuse instead of going through the back. I just don't like how they look, I feel like they look cheap and like a high school rig up job
Old 02-19-2022, 06:47 PM   #8
17rsvert
17rsvert's Avatar
Drives: 2017 HBM 2LT RS Convertible V6 A8
Not sure what type of lights you are installing, maybe something in this post might help https://www.camaro6.com/forums/showthread.php?t=564653
17rsvert is offline   Reply With Quote
