Old 02-13-2022, 02:55 PM   #1
donaldp
Drives: 2017 Red Hot ZL1 M6
Battery
My 2017 ZL1 just turned 5 years old and I still have the original battery.
It seems that when batteries are mounted in the trunk, they last a great deal longer.
My 2006 Dodge Charger had its battery in the trunk and it lasted 12 years.
Are others still on their original battery in their Camaro?
donaldp is offline   Reply With Quote
Old 02-13-2022, 02:59 PM   #2
Allez
Allez's Avatar
I put in a new battery in my 2016 2SS when it hit 5 years old. The old one was working OK, but with the new one I noticed it didn't need to crank as much to start.
Allez is offline   Reply With Quote
Old 02-13-2022, 03:21 PM   #3
bigd1276
2017 HyperBlue 2SS
bigd1276's Avatar
Drives: 2017 HyperBlue Camaro 2SS
Replaced mine at the 5 year mark. Right before putting her away for the winter.
http://www.camaro5.com/forums/showthread.php?t=30755
2010 IBM 2LT RS......Traded for.....
2012 IBM 2SS RS......Traded for.....
2017 HBM 2SS
bigd1276 is offline   Reply With Quote
Old 02-13-2022, 03:22 PM   #4
ctrlz
Original battery on my 2017.
Maybe trunk location on some vehicles has less vibration.
I never expect more than 7 years from a battery. We'll see where this one ends up.
Old 02-13-2022, 04:18 PM   #5
donaldp
...and less heat.
Old 02-13-2022, 04:46 PM   #6
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Certainly there's less heat in the trunk. I replaced my Camaro's battery after 6 years as preventative maintenance, based on experience with other cars: Recently, I had two SUV batteries die after a bit under 5 years.
Still, batteries are inexpensive. I don't see the point of trying to go over 7 years and risking a failure in an inconvenient or even dangerous situation.
Old 02-15-2022, 08:20 AM   #7
kpgreenwell
kpgreenwell's Avatar
Drives: 2017 50th anniversary edition v6 A8
2017 Camaro here. Still have original battery.
kpgreenwell is offline   Reply With Quote
Old 02-15-2022, 08:31 AM   #8
Outahand
Drives: 2018 ZL1
I just bought a new Odyssey battery for my 2018. Being proactive.
Plus the ZL1 was my only vehicle without an Odyssey. I have had outstanding luck with them. Have not replaced one yet. The one in my Vista Cruiser is 15 years old.
Mark E.
2018 ZL1 NGM A10
87 Grand National. Modified Hot Rod for sale *SOLD*
87 Grand National. Stock
65 Olds Vista Cruiser wagon Grand National motor/tran
66 Bronco Rockbuggy
2006 Dodge 2500 4x4 Cummins 6 speed
Outahand is offline   Reply With Quote
Old 02-15-2022, 08:52 AM   #9
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
I'm passing 4 years and I'm thinking if I by the slimmest of chances have it again next winter that I'll put a new battery in it. It cranks slow and after 3 days of sitting outside recently in <32 degrees it cranked pretty slow to the point I said "come on baby" before it lit. At least get it tested.
Old 02-15-2022, 09:13 AM   #10
ctrlz
This is one of the easiest things to test.
A $2 centech voltmeter from harbor freight will let you accurately check the resting voltage, which is an excellent indicator of battery "life."
Easier than adding washer fluid.
Old 02-15-2022, 09:23 AM   #11
tommcd24
tommcd24's Avatar
Drives: 2SS M6 NPP Convertible
To each their own, but with the prevalence of relatively inexpensive battery jump packs, I see no reason to replace batteries proactively. If your battery is 5-6+ years old, just throw your jump pack in the trunk. If it fails to start, jump it with the pack and then go buy the new one.
Batteries are also relativley inexpensive, but if you can get an extra 1, 2 or 3 years out of it, why not?
2SS Convertible M6 NPP Riverside Blue w/ Silver Rally Stripes
Dec. 18: took her home
Dec. 9: arrival at dealer
Nov. 16-29: Toledo, OH (railyard)
Nov. 9: 3800 -> 4300 (for stripes)
Oct. 8: 3400 status TPW 10/25
Oct. 6: 3100 status TPW 10/25
Sept. 9: 3000 status TPW 10/4/2021
Sept. 3: 2000 status (after 5 1/2 months)
Sept. 2: Change Order: 2SS (V6 constraint)
April 12: Reordered as ‘22 3LT RS V6 (March 16:Initial Order ‘21 3LT RS V6)
tommcd24 is offline   Reply With Quote
Old 02-15-2022, 09:25 AM   #12
wavsine
________/\_
wavsine's Avatar
Drives: Gen6 NGM RS
Send a message via Yahoo to wavsine
The Gen6 has an AGM battery. That is the primary reason. AGM can last up to 7 years, flooded batteries around 3-5 years.
wavsine is offline   Reply With Quote
Old 02-15-2022, 09:36 AM   #13
ctrlz
I don't think all models got them in 2016-17. Maybe now. I'm pretty sure my 2017 is flooded cell. Never looked that hard to be honest.
I've had AGM batteries fail in under 5 years.
Battery life projection is part technology/part voodoo.
Old 02-15-2022, 10:16 AM   #14
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
replaced mine 3 years in just replaced last year with lightweight antigravity one its awesome and lost 40lbs
