Old 02-04-2022, 02:27 PM   #1
kdm123
Drives: 2018 ZL1-1LE
ZL1 rotors: when to replace
On other cars I've tracked, I replaced the rotors once I saw significant cracks. On my ZL1, I've been surprised how many track days (well over a dozen) I've done w/o seeing any cracked rotors. I am worried though about wear. Do you guys replace your rotors when they are down to a minimum thickness, or do you use some other criteria.
kdm123 is offline   Reply With Quote
Old 02-04-2022, 02:40 PM   #2
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
when they hit the minimum thickness or throb on braking its time to replace.
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
Old 02-04-2022, 02:40 PM   #3
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
post up some photos
Old 02-04-2022, 07:44 PM   #4
kdm123
What is the minimum thickness?
Old 02-04-2022, 08:17 PM   #5
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
IMHO minimum thickness will not come into play as that is a measurement used when rotors were machined back in the day...rotors are throw away these days. The only thing to be concerned with is severe cracking which extends to the edge and your fingernail can catch. Crazing or checking is OK and expected. The only way you could wear a significant amount of rotor material is to run the pad down to the backing plate and score it metal on metal.
Old 02-04-2022, 10:11 PM   #6
Here are the rotor specs (option code J6H for the ZL1, J6M for the SS 1LE) for the record anyway.
Old 02-05-2022, 02:23 PM   #7
kdm123
So just to confirm, there is no need to replace a rotor unless there is significant cracking or they've been damaged from the backing plate?
That's the criteria I went by when I owned my C5 Z06.
Old 02-05-2022, 07:45 PM   #8
Stephen12ZL1
Drives: '21 ZLE A10
These ZL1 rotors are way more meaty than a C5 Z06 rotor. Yes, run until cracked or damaged as there is no reason to get crazy with a thickness gauge. I have never been more confident with brake parts/components as I am in a ZL1. If you read the chart above, GM allows for 1.5mm of scoring and 2mm of metal wear which is a ton!
