![]() Drives: 2018 Chevy Camaro ss 1LE Join Date: May 2020
Goodyear 3R tires
What do you think of your G3Rs
Last edited by CC2018SS1LE; 05-03-2022 at 02:08 PM. Reason: Tires were fine, just did not heat them up ent |
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
They don't typically have much fall off until they are corded. They are more temperature dependent, so if the ambient temp is less than 50 F it takes several aggressive laps to get them in the right operating range.
![]() Drives: 2021 1SS 1LE Join Date: Nov 2020
Pressure?
It was in the 70s drove many laps hard, tried different air pressure, tires were dangerous. First time ever, I had to use traction control.
#7 |
I've been using them for years and never experienced much of a fall off. Even flipped them on the rim and tracked them to they were worn down evenly. 19" 305/20 square. Are they old or been exposed to freezing temps?
#8 | |
I drive car on street, so use only 2 deg negative camber in front. When the tires were the best, I ran at 38lbs, took 4 seconds off, my best time with regular G3’s Thx |
#9 | |
Went back to Sebring last week, sliding all over the place. When they are cold, they feel like old hard tires, you can not even put your finger nail into it. I have to ck date code, maybe they sent me old tires. I think I paid almost 2k for stock 20in set Thx |
#10 |
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '21 ZLE A10 Join Date: May 2012
I have been through probably 15 sets of 3Rs and they seem to be about the same all the way to the cords as stated above. They are extremely sketchy when the ambient is cold and need to get up to temp. Cold starting pressure at 26-27psi always seems best working up to maybe 36psi hot max. GM recommends 26 cold psi also.
#12 |
I start off about 28 psi cold and hot max is about 36-37.
#13 |
![]() ![]() ![]() Drives: 2017 1SS 1LE Join Date: Jun 2016
In my experience they're great until cords are showing, they get cold, or then get around 3 or 4 years old depending on how they were stored. Based on what was tried before my first guess would be age or how they were stored. I've also heard a few people say when they get into them and start over-driving them they can get greasy, but that's not something I've experienced for myself and doesn't seem to be a common thing.
2017 SS 1LE.
#14 |
![]() Drives: 19 ZLE A10,17 SS 1LE, 16 C7R,CT5V Join Date: Feb 2017
Should be good all the way to cords.
