![]() Drives: 2021 ZL1 Join Date: Sep 2021
2021 ZL1 Squeaky Pulleys
I have a brand new 2021 ZL1, and every time it starts I get squeaky belts/pulley sounds for the first 30 seconds or so. Is this a known issue? Is there anything I can do to get rid of this? I searched the forums and I did not see any mention of this. Thanks.
I had a very similar thing occur when I bought my car in 2019. I had less that 2k miles and I heard a very light squeak from the front drive. I used a bearing stethoscope I had on hand along with the old screw driver to the ear trick to narrow it down to an idler pulley for the supercharger belt. I brought it back to the dealer under warranty and it was in fact that pulley which they replaced for no charge of course. Sometimes you just get a defective part here and there unfortunately. I’d think the same is the case for you if you can confirm it’s from the front drive.
Morimoto Headlights, AWE Touring Catback, MM Catch Can, ADM V2 Reservoir, Roto-Fab, C&R Oil Cooler, 1LE Grills
#3 | |
#4 | |
Coupe Newbie
Drives: '23 CT5-V BW, '21 Corvette HTC Join Date: Jul 2011
My ‘17 ZL1 squealed for 15-30 seconds on cold startup during the first year of ownership. I posted a YouTube video on here to see if the engines of other Zl1 owners made the same noise when their cars started up. The consensus was no. I’ll see if I can find video so you can compare it to yours. Midway through the second year of ownership, the bearing on the supercharger idler pulley started squealing all the time. The pulley was replaced under warranty. The new pulley has been squeal-free. Good luck. The dealer may not be able to diagnose unless you leave the car for a few days in order for them do a cold startup. Here’s a photo showing the pulley that was bad on my car.
Coupe Newbie
![]() Drives: R.I.P. 2021 ZL1 & 2019 Rd Garn 2SS Join Date: Dec 2019
I'm no expert but that don't sound right at all.
#7 |
Coupe Newbie
I didn’t think so either. I had one other ZL1 owner tell his engine did the same thing.
As you can hear, the noise starts to dissipate as the engine idle starts to go down. It did this for about a year and half until the bearing finally crapped. When that happened the squealing noise was constant and a lot louder. I used a long wooden dowel to diagnose which pulley was bad. You could hear it buzz and vibrate like a nest of angry bees.
#8 | |
![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL1 Join Date: Mar 2019
This here is a very easy to diagnose bad bearing on a pulley. I've heard many others, and alot of times its very hard to tell. This here though is very easy as you can hear the grinding/vibrating stopping and starting which is a clear giveaway. If the OP's sounds like this replace it now before it falls apart
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
#9 |
Sounds just like a louder version of my pulley which was also an idler for the supercharger. In my case it was directly below the snout of the blower but I agree with everyone that you should definitely get it checked out.
