Old 01-27-2022, 01:19 AM   #1
schoenmaro55
schoenmaro55's Avatar
Drives: 2021 Camaro 2SS 1LE
Really Bad Day
I have to tell you... I had a really bad day. I'm really disappointed in GM. I realize what you are about to tell me is nothing new, but that still doesn't make it right.
I bought a 2021 2SS 1LE Camaro in September as the second owner. It had 5,300 miles on it, now it has about 9,700 miles on it. I took my car to my local dealer which is actually VERY good.
I heard something sound sort of weird in the engine bay. To no one's surprise, those stock "cheap" lifters are going bad on the driver's side. Per GM warranty, they will only replace the broken side under warranty.
We made the choice to do nothing for now and we're going to wait until I get a check engine light, get some misfires, or it starts sounding way worse.
Mine is a manual so I thought I escaped the AFM/DOD lifter issue, but I was clearly misinformed on that and it turns out I have the same crappy lifters. So for now, it's just let it run until it gets worse and use the same crappy stuff while it's under warranty.
The only way to make it right is new lifters, new heads, new cam.... but I have to tell you, for a car that cost more than $50k.... the last thing I want to do is put a ton of money into the engine lol.
I bought this car to get away from a bad experience I had with a Mustang GT and my experience 4 months in with this car is already tainted. I'm upset at GM for cost cutting and using cheap parts of such a potent, powerful V8 engine. I'm not even sure what to think of the car anymore.
I love the way it drives, but I'm not sure what's next. I'm really frustrated. Just wanted to vent.
2021 Camaro 2SS 1LE Riverside Blue "Midnight"
schoenmaro55 is offline   Reply With Quote
Old 01-27-2022, 06:54 AM   #2
Spaceme1117
Spaceme1117's Avatar
Drives: 2017 Camaro SS, 2011 Corvette GS
I feel your pain. Went through a warrantee ordeal with a Chevy Cruze about 10 years ago but that was because the dealership service department was completely incompetent.
If the dealership is good, they will take care of it and the car will be fixed.
The 6th Gen Camaro is one of the best cars made today. So hang in there.
Spaceme1117 is offline   Reply With Quote
Old 01-27-2022, 07:16 AM   #3
Uncle Sam
Drives: 2017 Camaro 1LE Hyper Blue
I had a lifter collapse passenger side, at 700 miles. Had it fixed, just the right-side lifters and it ran fine after that, track days included. I don't understand why you wouldn't get this fixed under warranty. You could have greater damage and wipe a camshaft and have to go deeper into the engine.
Uncle Sam is offline   Reply With Quote
Old 01-27-2022, 07:25 AM   #4
BrandanK
Drives: 2021 Camaro SS 1LE
I agree with Uncle Sam; why wait until you trash more of the motor?
While I agree that the lifter could damage the cam; I'm not 100% sure that the heads/valves are going to be troubled by a bad lifter. If replacing the failed lifters doesn't work, then GM will fix another failure later also. Furthermore, if you are worried about the other parts not being replaced, ask the dealer if they will replace the other parts at "parts cost" only since labor will be covered under powertrain warranty.
I would be cautious, as now GM can say that you chose to walk away from a repair that would have been covered under powertrain warranty.
BrandanK is offline   Reply With Quote
Old 01-27-2022, 08:32 AM   #5
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
There's no reason to not get the lifters now, letting it get worse to possibly a whole top end isn't going to help anything. I think that that'd way hard on my mind and takes all the joy out of the car thinking every day when I stomp on it it's gonna be a catastrophic failure because I knew it had a bad lifter already. I would have to imagine that it's down on power but I'm not *that* knowledgable of a bad lifter.
Old 01-27-2022, 10:02 AM   #6
m6-lt1
m6-lt1's Avatar
Drives: 2023 Chevrolet Camaro 2SS 1LE
I would get it fixed asap and try what BrandonK suggested. Gm could possibly deny fixing it if it got worse because you didn’t let them fix it in the first place when it was a smaller job.
On a side not Chevy seriously needs to get their **** together. They had valve spring issues for 2020 models and now are having lifter issues for 2021 models. I seriously hope there’s nothing wrong with 2023 models since I plan on eventually moving up to a used Zl1. Not to mention valve spring issues on c5z’s and valve guide issues on c6z’ as those were cars I was considering before I bought my 6th gen. I don’t know how after decades of developing engines things like this still happen where they get/make a bad batch of something.
m6-lt1 is offline   Reply With Quote
Old 01-27-2022, 10:17 AM   #7
GearheadSS
GearheadSS's Avatar
Drives: 23 LT1/86 IROC-Z
This all day. You do not want to have to replace the engine as you could be waiting for months for a new one. Replacement 6.2s are a national backorder issue right now. We have a vehicle that has been waiting on a new 6.2 engine from GM for almost 3 months now.
Even the lifters will likely take some time to get. Have your dealer get them ordered and then drive your car until they come in. Get it fixed asap.
Old 01-27-2022, 10:32 AM   #8
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
Right now you're intentionally damaging your engine because you're upset. Just sayin... GM may deny your claim. I would if I was the manager.
Old 01-27-2022, 10:49 AM   #9
GONIF
GONIF's Avatar
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE
Get the repair done ASAP . If the dealer is good they will replace all the parts needed, and you will be still on warrantee if anything else go's wrong. Give them a chance to make it right .
OLD GUY FLYING FAST AND LOW
GONIF is offline   Reply With Quote
Old 01-27-2022, 11:37 AM   #10
WhyUMad1LE
Drives: 17 SS 1LE
Why bother with a warranty repair when you can just sell the car without disclosing the issue?
Old 01-27-2022, 12:04 PM   #11
MightyBobo
MightyBobo's Avatar
Drives: 2022 VOM 2SS 1LE M6 Camaro
This is insane. Who'd walk away from a free warranty fix that if left ignored, may damage the engine further? C'mon, guy.
2022 Vivid Orange 2SS 1LE ordered (BDQDHT, 1G1FG1R7XN0108251)
20211120 - 1100 --- 20211207 - 2500
20211208 - 3000 (TPW: was 20220103, now 20220124)
20211220 - 3400 (TPW: 20220110)
20220114 - 3800 --- 20220122 - 4300 (1LE Wrap Shuffle)
20220125 - 4B00 --- 20220129 - 4200 (Shipped! ETA: 20220223)
20220212 - 4800 --- 20220216 - 6000!
2024 Silverado 1500 LTZ 3.0 diesel
MightyBobo is offline   Reply With Quote
Old 01-27-2022, 12:09 PM   #12
s346k
s346k's Avatar
Drives: like an old lady
id say it's simply bad luck and not normal. i've been shifting my stock long block bolt on car at 6800+ for the last 10,000 miles. it has 32k on it now. with that being said, i've been expecting lifter issues.
edit: i agree with those telling you to have the car repaired asap. youre risking much more damage leaving it be.
Old 01-27-2022, 12:17 PM   #13
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Here's the fix.
Get one side repaired under warranty, for peace of mind, YOU pay to have them do other side at the same time.
EASY.
ing for grip.
http://www.motorsportsne.com/
Old 01-27-2022, 12:55 PM   #14
Duramacr1
2Spdsy
Duramacr1's Avatar
Drives: 2021 Camaro LT1 A10
Time for a cam swap.
Duramacr1 is offline   Reply With Quote
