Old 01-25-2022, 07:51 AM   #1
DrBlockHed
Drives: 18 ZL1 Convertible
Reverse LEDs
One of my reverse lights went out, needs to be changed out. Figured I’d go the LED route while doing it. I’ve did a search and read some questionable things about the Phastek resistor and quality of their LEDs.
Any recommendations? Thoughts on the gen5diy or diode dynamics one?
Thanks
DrBlockHed is offline   Reply With Quote
Old 01-25-2022, 08:13 AM   #2
infinitereality
Limitless Imagination
infinitereality's Avatar
Drives: 2018 ZL1 & 2022 Hayabusa
Thanks
I run Gen5DIY harness on mine with Amazon LED bulbs, the harness is their new one. It's solid state and no resistors now.
2018 Camaro ZL1 - Black
- OEM Options: A10, Exposed Carbon, PVR, Nav, No Sunroof
- Lightly Tinted GM Dark Tails, DD Side Markers, Morimoto 5000k, 100% LED
- RotoFab Dry, Forgestar CF5V (ZLE Spec), Eibach Pro, AeroForce Interceptor, GT4 Tow Hook
- Carbon Fiber (Satin): Radio, Shifter, Steering Wheel Controls, Shifter Top, AC Vents, Side Mirrors & Shark Fin
2022 Suzuki Hayabusa - Brilliant White Pearl & Shocker Yellow Wheels
- +4 Arm, 240 OEM Wheel, Brock's CT (Ti) Exhaust, 1.25" drop, etc...
infinitereality is offline   Reply With Quote
Old 01-25-2022, 08:22 AM   #3
ZLE dude
Drives: '18 ZL1 1LE
I run the Gen5DIY pigtail/resistor on a Diode Dynamics LED bulb. Has worked great for the past 2 years.
I purchased the XPR bulbs (brightest ones, 90 bucks). They are super bright and work great with my 5% window tint.
https://www.diodedynamics.com/backup...maro-pair.html
Here is the harness from Gen5DIY....obviously this is for 2016-18 so if you have a '19 and up there's a different one. Just telling you what I've got.
https://www.gen5diy.com/products/16-...mp-led-harness
2018 ZL1 1LE - Summit White, PDR, Rotofab CAI, 95mm TB, CSP 2" catless LT's, JMS Voltage Booster, AEM X-series WB, DSX flex fuel sensor, Banks Data Monster, Tuned by Ted Jannetty, 5% Tint, Blackvue DR900S-2CH, Diode Dynamics lighting, IGL Kenzo ceramic coating
ZLE dude is offline   Reply With Quote
Old 01-25-2022, 08:31 AM   #4
DrBlockHed
Any reason you didn’t run gen5s bulbs
Old 01-25-2022, 08:53 AM   #5
infinitereality
IMO overpriced for generic LED bulbs that can be purchased cheaper. They visually appeared to be old school generic LED bulbs.
Old 01-25-2022, 10:19 AM   #6
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
gen 5 harness and diode dynamics led lights for me
Old 01-25-2022, 10:27 AM   #7
DrBlockHed
The harness is just plugged inline behind one taillight, correct? The picture looks like there are 6 connections
Old 01-25-2022, 10:30 AM   #8
infinitereality
Yep, you get 2 Gen5DIY harnesses. 1 for each light and plugs in line.
Old 01-25-2022, 10:59 AM   #9
DrBlockHed
Ahhhhh, phastek only had one… that makes more sense.
Thanks
Old 01-25-2022, 11:44 AM   #10
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I know my '20 uses a different kind of harness, but, I tried a cheap Amazon set, and they're working great so far. I felt like if I didn't like them, or they didn't work, I wouldn't be out much $$$, and so far, I'm pretty happy. I don't get to drive my car as much as many of you, so I can't speak to their life, but I've had them on the car since about 10/19 and have about 2800- miles on the car now, for reference.
'20 ZL1 Black "Fury"
Old 01-25-2022, 02:50 PM   #11
DrBlockHed
Would u mind linking the bulbs you used?
Old 01-25-2022, 03:18 PM   #12
zxspeedspec
Drives: Faster than yours
I just installed these last week. My reverse lights are about as bright as the stock headlights.
http://www.highperformancebulbs.com/...1156-7440.html
zxspeedspec is offline   Reply With Quote
Old 01-25-2022, 05:54 PM   #13
DrBlockHed
Old 01-27-2022, 01:36 PM   #14
graf101
Trouble_SM
graf101's Avatar
Drives: 17' Summit White ZL1
Phastek ftw
graf101 is offline   Reply With Quote
