Old 01-22-2022, 10:30 PM   #1
Alex.ZL1
Drives: 2018 ZL1 NFG A10
Oil pump failure 😞
Had oil pump failure today at 12,898 miles. Car is an 18 built in aug 2017 in normal city traffic driving. My question is, how many of you had this failure and had the oil pump replaced with out any damage to the engine. Metal is my concern and I will know a lot more in next week or so but on the off chance the dealership only wants to replace oil pump, is that the smartest thing. Does a oil pump going down always require a new engine? I’d love to hear your experiences with this issue and what the dealership did for you? Car was only driven about a 1/10 of a mile after the failure
Second question, does the newer GM pumps fix the issue. My dealership does not want to authorize a katech pump in place of OEM under warranty…
Alex.ZL1 is offline   Reply With Quote
Old 01-22-2022, 11:15 PM   #2
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
my pump crapped out at idle and it was fine. Engine was not damaged.
Old 01-23-2022, 12:03 AM   #3
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
Here is a long thread on the topic:
https://www.camaro6.com/forums/showthread.php?t=532479
Old 01-23-2022, 12:43 AM   #4
Alex.ZL1
Yes I know but reading through it didn’t answer some of the questions I had above. Everyone talks about the failures but not so much about if the engines were replaced
Old 01-23-2022, 01:32 AM   #5
Wuiquen
Wuiquen's Avatar
Drives: 2018 Hot Red ZL1
I don't think many have had the engine replacement. Most that i have seen in here is just new oil pump. No one really knows for sure if the new oil pump won't break. However, we have not seen failures in many 2019 and up. If anything only a few. It seems that it was a batch of oil pumps that went into 2018s mostly.
Don't worry. I bet you will be fine. But while you are at it, you could add some cams if you want to mod the car. I bet other will pitch in soon. My car had it replaced and i haven't had any issues. It's been like 2k miles
Sent from my moto g(7) power using Tapatalk
Old 01-23-2022, 01:52 AM   #6
Alex.ZL1
That’s excellent news. I’m hoping Oil Pumps won’t be on back order either
Old 01-23-2022, 06:26 PM   #7
scooter k
Drives: ex-wife's car
Buy the Katech pump and have them install that.
scooter k is offline   Reply With Quote
Old 01-23-2022, 07:32 PM   #8
Spaceme1117
Spaceme1117's Avatar
Drives: 2017 Camaro SS, 2011 Corvette GS
I have a 2017 SS. Bought it used last year. Carfax showed it had the oil pump replaced at 10K miles. Car is now at 47K. Runs great, no problems.
Spaceme1117 is offline   Reply With Quote
Old 01-23-2022, 07:47 PM   #9
Alex.ZL1
Dealership won’t let me
Old 01-23-2022, 09:04 PM   #10
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Just have them replace it. The newer pumps are fine.
If you wanted the Katech installed your most likely going to have to bypass the warranty process.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 01-23-2022, 11:28 PM   #11
Alex.ZL1
Hopefully a clean break and no metal throughout. I will know more hopefully soon. The dealership said they don’t know much about this issue and have never seen one. I hope they don’t jerk me around. Is there an actual TSB out on this yet
Old 01-24-2022, 12:46 AM   #12
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Theres a TSB about it and the timing chain tensioner spring which could be the cause.
PIP5407A I believe is the TSB.
and here https://gm-techlink.com/?p=12041
Old 01-24-2022, 06:42 PM   #13
SteveV
SteveV's Avatar
Drives: 2018 ZL1 Camaro 6M Red Hot
Well, if you had read my post, you would have noticed that I specifically pointed out that after the tech opened up my bottom end, he found only some scoring on 1 bearing. So, he replaced all of my main bearings and the oil pump.
No engine swap was necessary.
This was about 7000 miles ago. Car runs great.
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
SteveV is offline   Reply With Quote
Old 01-24-2022, 07:34 PM   #14
scooter k
I'd install it if I was closer. I don't get why they won't but every dealer is different I guess.
