01-21-2022, 11:40 PM | #1 |
Drives: 2020 Camaro SS 1LE | Satin Steel Join Date: Jan 2022
Exhaust leak between cats and AWE cat back bad?
Hey everyone, I just installed my new AWE Track Edition Cat Back on my 2020 SS 1LE. I have a mild exhaust leak at the join between the awe system and the secondary cat on the passenger side. I wanted to know if this is worth fixing. I can't seem to get the leak to stop by adjusting the pipe, so my last resort was going to be to weld it. Any ideas?
01-22-2022, 08:46 AM | #2 | |
01-22-2022, 07:13 PM | #3 |
Well there's nothing good about an exhaust leak, so if it was me I would fix it.
01-22-2022, 08:09 PM | #4 |
Drives: 2018 2SS 1LE Black Join Date: Aug 2018
They actually recommend using exhaust sealer on the slip joints, don't weld it it will rust off in that area S/S or not. https://www.amazon.com/Permatex-Muff...omotive&sr=1-2
01-23-2022, 11:59 AM | #5 |
I agree with sealing it.
This what I have used to seal exhaust joints: https://www.amazon.com/Permatex-8187...79&sr=8-2&th=1 |
01-23-2022, 12:40 PM | #6 |
Hail to the King baby!
Drives: '19 XT4 2.0T & '22 VW Atlas 2.0T Join Date: Dec 2008
Let's just say it's not good. If your body is perfectly sealed and if you never drive around with your windows down you just might be safe from a leak. Best case you can smell it. Worst case? That's where it's not good.
Get it addressed.
01-23-2022, 12:44 PM | #7 |
Drives: 2017 Camaro SS, 2011 Corvette GS Join Date: Feb 2019
Definitely seal it. Just use some Permatex Exhaust sealant.
I just had a loose rear O2 sensor and it played havoc with all of my O2 sensors causing my car to throw several codes. |
01-27-2023, 09:22 PM | #8 | |
Drives: 2018 Camaro 2SS Join Date: Jan 2021
