![]() Drives: 2018 Chevrolet Camaro SS Join Date: Feb 2021
2018 Camaro SS - Fitting DRLs...
Hi all,
I am in the process of turning my 2019 (2018 MY) EU-spec SS back into the car it SHOULD be. Having done the easy bit (badges!) I'm now working on adding the lower grille DRLs. I have a set of these plus wiring looms (from GEN5DIY) but what I don't have is mounting hardware. Can someone advise what is needed please? Thanks!! Chris |
UK2019
Drives: Camaro 2017 2ss/eu spec convertible Join Date: Mar 2019
Drl hardware
Hi. I added the drls (and side marker lights) to my eu spec camaro. In addition to the wiring you'll just need 3 bolts per light. They weren't supplied with the lights I bought but I had some laying around from previous cars (sorry I don't have the specs of length diameter or pitch). The holes in the bumper are already threaded and ready to take the hardware.
Thanks!! Can anyone provide the part numbers for the bolts so that I can order the correct ones?
Long hauler
https://www.gmpartsdirect.com/v-2018...amp-components
#2 is the bolt, get three of them and maybe even #3 depending on if you have them or not
2016 1LT v6 - Totaled Happiness: Infinite |
Awesone - thank you!!
