Old 01-21-2022, 02:32 AM   #1
AmbientLighting
Drives: 2019 camaro SS 2 SS
Why is my Camaro SS so powerful?
Isn’t this abnormal? All Stock besides the tune and custom vacuum house reroute. Pump 91 AZ gas. Also have silicone intake pipe. Please advise.
AmbientLighting is offline   Reply With Quote
Old 01-21-2022, 02:36 AM   #2
Camaro fanboy
Camaro fanboy's Avatar
Drives: 2017 2SS Arctic blue fully loaded
i'de be more concerned why my camaro is loosing coolant.
Camaro fanboy is offline   Reply With Quote
Old 01-21-2022, 06:08 AM   #3
wwiiavfan
Drives: 2017 1SS Hyper Blue
Are you the original owner? If not, you can’t say 100% certain it is stock. It may have been modded. Engine cover is missing, why?
wwiiavfan is offline   Reply With Quote
Old 01-21-2022, 06:30 AM   #4
Spaceme1117
Spaceme1117's Avatar
Drives: 2017 Camaro SS, 2011 Corvette GS
Assuming your car is stock, the dyno is not calibrated.
Spaceme1117 is offline   Reply With Quote
Old 01-21-2022, 06:40 AM   #5
ALMN
ALMN's Avatar
Drives: 2SS 1LE M6, Palisade Calligraphy
Dynocomp is the most generous dyno out of all. One way to test it is do some 0-60 and quarter mile runs see if the dyno results match the reality.
ALMN is offline   Reply With Quote
Old 01-21-2022, 07:26 AM   #6
LT1gen6
LT1gen6's Avatar
Drives: '22 LT1 Coupe
No vehicle identifiers on performance data sheet? Random data sheet + random engine pic is not much evidence of anything except likely provocation.
LT1gen6 is offline   Reply With Quote
Old 01-21-2022, 07:31 AM   #7
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Why are you asking a question like that anyway? It is an SS that has had some mods done correct? Like someone replied, I would be more concerned about the low coolant in the top reservoir.
Old 01-21-2022, 08:54 AM   #8
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Old 01-21-2022, 08:59 AM   #9
Need4Camaro
Drives: '17 Camaro 2SS & '99 Camaro Z28
First thing that came to my mind when I saw the missing engine cover was LT2 intake.
Need4Camaro is offline   Reply With Quote
Old 01-21-2022, 10:10 AM   #10
L78toLT1
L78toLT1's Avatar
Have your tuner check to see if it's been tuned. I suspect this car was formerly modded and was returned to as close to stock as possible before being sold. I'll wager the car still has a tune, and possibly a few more hidden mods. The aftermarket elbow connected to the oem CAI is odd. Nothing wrong with that, but it's just not normally done.
Baby Blue
Old 01-21-2022, 10:29 AM   #11
ctrlz
Just looking at reported 460 vs rated 455 HP, that's 1% error.
That's actually quite excellent from everything I read about dynos.
Old 01-21-2022, 10:55 AM   #12
Need4Camaro
455 HP is rated at the flywheel, not the rear wheel… Stock LT1’s are going to put down in the ball park of 380 - 420 HP on a dyno depending on the dyno and cars transmission.
Old 01-21-2022, 11:17 AM   #13
TXCSSU
Drives: 2022 ZL1 M6/Nissan Leaf
Looks like your dyno shop knows that if they inflate their numbers, more people will come in to polish up their egos...
The best shops give you the real numbers, even if it's a lower number than you're expecting.
TXCSSU is offline   Reply With Quote
Old 01-21-2022, 11:23 AM   #14
ctrlz
excellent point.
then it's ~10% error.
still think it's a dyno problem and not a super-duper extra powerful car problem.
