Old 01-20-2022, 06:09 PM   #1
TraderGuy
Drives: Audi TT-RS
Outside Track Width?
I'm considering picking up a ZL1 1LE. This site has been a great resource for my research.
I'm wondering if someone could measure the outside rear width of the car, tire to tire. I'm trying to figure out if a ZLE would fit on my lift. A widebody C7 does, but barely. The Track Width in the specifications looks to be center to center.
Thanks!
TraderGuy is offline   Reply With Quote
Old 01-20-2022, 07:50 PM   #2
Higgs Boson
Perpetual Order
Drives: indeed
just add the rear tire width to the published track width plus 3 inches for a 1.5 inch buffer on each side. so basically add like 15 inches to the published rear track width.
Higgs Boson is offline   Reply With Quote
Old 01-21-2022, 09:45 AM   #3
TraderGuy
Drives: Audi TT-RS
Good thought. Based on that info, looks like it will fit. Thanks.
Old 01-21-2022, 09:56 AM   #4
Idaho2018GTPremium
Idaho2018GTPremium's Avatar
Drives: 2021 Camaro ZL1 A10
My '21 ZL1 outside rear tire to outside rear tire is ~76". ZLE is probably another 1" or so given the tire width differences.
2021 Camaro ZL1 A10
2022 GR Supra 3.0
Past:
2018 Mustang GT Premium w/ PP1, MR, and A10
2007 MazdaSpeed3
1995 Pontiac Trans Am
1987 Camaro Z28
Idaho2018GTPremium is offline   Reply With Quote
Old 01-21-2022, 01:21 PM   #5
CW3SF
CW3SF's Avatar
Drives: 2019 Chevy Camaro ZL1 M6
You can overhang the tires on each side by an inch or so if needed and it’ll sit fine. I’ve done it on my cars many times.
CW3SF is offline   Reply With Quote
Old 01-21-2022, 02:33 PM   #6
Higgs Boson
Perpetual Order
Drives: indeed
A lot of lifts have a covered pulley at the top of the ramp blocking the ability to allow that.
Old 01-21-2022, 03:40 PM   #7
CW3SF
CW3SF's Avatar
Mine has that too but is several inches wider than the tread path on each side. Meaning you can hang off the tread path an inch or two on each side no problem. I haven’t seen one that’s only clearanced to the tread path but I guess anything is possible.
Old 01-21-2022, 05:03 PM   #8
TraderGuy
Drives: Audi TT-RS
I've got just under 80" Pully Cover to Pully Cover. For sure the tires would hang off of the runways. It would be close.
