Drives: Faster than yours Join Date: Nov 2021
Easiest access to both headlight bulbs
Looking to replace my headlight bulbs with something brighter since my county refuses to install light posts for our country roads. If I have the carbon fiber CAI intake, is it easier accessing both high beam and low beam through the fender or is it easier removing the intake?
What about the opposite side of the car? |
![]() Drives: 2017 ZL1 A10 Summit White Join Date: Apr 2018
I just replaced my driver side one. It can be done by just removing your intake. It's a pain in the ass, but I did it. Passenger side, could be hard. Luckily mine wasn't out, so I didn't have to tackle it. But I was curious and wanted to see if I could do it and honestly it looked impossible. Good luck.
#3 | |
Limitless Imagination
Drives: 2018 ZL1 & 2022 Hayabusa Join Date: Dec 2016
It's been a bit since I put them in, but I believe I turned the wheel, removed some of the screws for the fender liner and had pretty easy access to them. I also swapped in some Lasfit LED front signals, but as you probably already have noticed that they're easy to install from under hood
2018 Camaro ZL1 - Black
- OEM Options: A10, Exposed Carbon, PVR, Nav, No Sunroof - Lightly Tinted GM Dark Tails, DD Side Markers, Morimoto 5000k, 100% LED - RotoFab Dry, Forgestar CF5V (ZLE Spec), Eibach Pro, AeroForce Interceptor, GT4 Tow Hook - Carbon Fiber (Satin): Radio, Shifter, Steering Wheel Controls, Shifter Top, AC Vents, Side Mirrors & Shark Fin 2022 Suzuki Hayabusa - Brilliant White Pearl & Shocker Yellow Wheels - +4 Arm, 240 OEM Wheel, Brock's CT (Ti) Exhaust, 1.25" drop, etc... |
I'd rather not assume HID or LED headlights, OP, what model year and trim do you have? Are you sure you have the base headlight assembly and there are separate low and high beam bulbs in the housing?
#5 | |
So... apparently I did **** up. I thought I needed H11 and 9005, but it's sounding like the ZL1 1LE uses the D3S HIDs?
#7 |
That would be correct!
#8 |
Brb, ordering different bulbs...
Sounds like I'll be pulling some fender lining. I'll have to look under the hood again, but depending on my airbox it may be the easier route to go anyway. |
#9 | |
I've ran Osram CBB bulbs in the past and excellent bulbs. I really wanted another set, but couldn't justify 3-4x the price of the Morimotos unless the CBB's output was 3-4x which isn't even close. What bulbs did you end up ordering? Other than myself, and now you, I don't think anyone else has bothered with upgrading bulbs.
#10 |
BanHamWatch
Drives: 21 ZL1 1LE Join Date: Jan 2021
Honestly yah the Led lights in my new base model Corolla are better than the HID in the ZLE
2021 ZL1 1LE
Auto |
#11 |
Not to sound like a salesman but if you don’t like the output and can afford the coin for a Morimoto/HERO set of housings along with the project they are by far and away worth it. Dual LED low and high beams in each housing absolutely blow the OEM HID’s out of the water for output and range, I couldn’t be happier with them and have zero regrets.
Morimoto Headlights, AWE Touring Catback, MM Catch Can, ADM V2 Reservoir, Roto-Fab, C&R Oil Cooler, 1LE Grills
#12 | |
https://precisionled.com/shop-by-bul...onversion-kit/ To be fair though I almost never drive this car at night and when I do I live in the middle of nowhere so there's almost no chance of me blinding someone. I think in the past 6 months I've only seen 2 other cars at night. What I do have are the dumbest deer in North America who hear the ZLE coming and think "play time!" |
#13 | |
BanHamWatch
2021 ZL1 1LE
Auto |
#14 | |
I'll be honest, I absolutely detest the douchebags that install aftermarket 12261785615 lux LEDs on their bro dozers and blind everyone for 5-10 seconds because who gives a ****. Doesn't even make sense, because the same blinded oncoming drivers can so easily veer into their trucks across the double yellow one day... These LEDs are probably not such a big deal on a low sports car such as the Camaro if the aim is set correctly, but on trucks and SUVs it's a nightmare.
