Go Back   CAMARO6 > Marketplace > Members Classifieds > 4-Cylinder - Engine, Exhaust, Bolt-Ons, Tuning Equipment
Old 01-18-2022, 03:23 PM   #1
southerncarparts
southerncarparts's Avatar
Drives: 2009 Corvette Z06
2016-2019 CAMARO SS SOLER PERFORMANCE PREMIUM MODIFIED 87MM THROTTLE BODY
The 2016-2019 Camaro SS Soler Performance Premium Modified 87mm Throttle Body increases air intake for more power!
FEATURES:
• Optimized Active Contours (Both Upstream & Downstream)
• Porting Taper and Upstream Bore (Lip & Bore Reduction)
• Greater Discharge Coefficient of Plate/Blade
• 16 Ra Microinch, Diamond Polished Surface Finish (Lower Skin Friction)
• Half-Shaft (Front & Back) for Larger WOT Flow Area (91 mm Effective Bore)
• Self-Cleaning Throat/Flow Gap
• Minimized Gear Backlash
• Countersunk, Thread-locked, and Peened Screws
• Made from Brand New OEM Parts
• Lower weight to power ratio at part throttle, for a more nimble/spirited driving experience (We doubled the rate of change of mass airflow (MAF) from 1.2 g/s-deg to 2.4 g/s-deg), 100% Increase!
• Linearization and smoothing of the curve for a more predictable response and crisper shifts
• Immediate response right off idling while keeping idling function undisturbed (No Hesitation/Stumble)
• Does not require tuning. Warranty safe.
• More air/power at every single throttle position after idle. Crucial for starting or expanding power gain modifications
APPLICATION: 2016, 2017, 2018, 2019, CAMARO 6 SS
southerncarparts is offline   Reply With Quote
Old 07-15-2022, 12:29 PM   #2
southerncarparts
Thank You for your orders
Old 03-23-2023, 12:25 AM   #3
southerncarparts
Thank You for shopping at https://www.southerncarparts.com/201...ttle-body.html
