![]() Drives: 2022 Camaro ZL1 Join Date: Jan 2022
Best Tires for Drag?
Hey Guys!
I just ordered a 22 ZL1 - who knows then I’ll have it but that’s besides the point It’s manual no track pack, so I have the 20” rims unfortunately What’s the best tires that are street legal that I can put on the stock rim? I’ll be dragging this thing at our local drag strip. Also what’s the Widest tire I can get on there without modding anything Thanks! |
I run 305/35/20 555r2 Nittos. On a unprepped surface I can manage a 1.7-1.8 60ft. Haven't been on a prepped track with it. Either way this tire imo is the best all around for traction, treadwear, and streetability. The MT Street R will hook better at the track but wear faster, balance is hit or miss, and they cause rear end wag at high speeds.
That being said to keep your front are rear in spec you will likely need a 305/30/20 555r2. Justin Keith went 1.5 60ft foot in his 19 C7 ZR1 with that tire. It ran 9.9 @ 140 with cai, tune, tire at a prepped track.
#3 | |
Thanks for info!! Think Nittos better than r888? |
![]() Drives: 2018 ZL1 Coupe NFG M6 Join Date: May 2017
The Nitto NT555RII in the stock 305/30/20 would work just fine. No need to run a taller size, it'll slow you down especially in a stick car.
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School 2017 Colorado Z71 <- Daily 2018 ZL1 M6 <- Not Daily |
MT ET Street on Forgestar F14, but only at the strip. Otherwise, Michelin Pilot Sport 4S on OEM wheels.
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq |
Former GM Technician
Drives: 2018 ZL1 A10, 06 Silverado Duramax Join Date: Sep 2009
Definitely more quiet, and better in the rain.
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, DSX dual intank pump, Lingenfelter high flow check valve, Motion Raceworks Flex Fuel adapter, LPE Big Bore Hpfp, XDI 30% Injectors, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can. 2006 Silverado Duramax Diesel MPI Compound Turbo 40% over Injectors Efi Live DSP5 Tuning Follow me on Instagram: SwissZL1 |
#7 |
![]() Drives: High HP V8 Join Date: Apr 2020
Nitto 555R2 for the street as your well rounded drag radial tire and a separate set of track wheels with some MT's on them for the drag strip.
#8 |
If you are on those tires then plan on catching lots of gaps from cars with less power.
#9 |
Moderator
Exactly. Any car with NT555R or R2, or Toyo R888R, will hook way better on the street than PS4S.
#10 | |
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq Last edited by JSH; 01-19-2022 at 07:52 AM. |
#11 |
I was at Gateway when Justiin ran in the 9s with his Zr1 at his street car takeover event. He has used the 555r2s on a bunch of his stuff including his 90s Silverado with the Lt4 swap. I've run them on my C7, had two sets including 305-35-19 for the street and 285-40-18 for drag racing. If I drag race my new Lt1 I'll run them on it also. I currently have the G2s on it and they pretty much match the 555R2s. He also ran them on his Track Hawk front and rear.
#12 |
![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL1 Join Date: Mar 2019
The nt555r2 is pretty much the best street drag radial you can buy. R888 are good too, but noisy and they wear quick and forget about the rain.
I’ve got to get them good and hot to hook at my power level but when hot they hook good. I use these for the street and I have my 17” drag pack for the track.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
#13 |
![]() Drives: 18 ZL1-1LE, 10 JKU Join Date: Jul 2018
i wonder if the 345/30/19 nitto would squeeze in a ZLE rear
#14 | |
2020 ZL1LE A10.
