Old 01-15-2022, 11:03 AM   #1
Dennis 2ss
Dennis 2ss's Avatar
Drives: Camaro 2SS 2017
Procharged LT1
Hey guys i currently have a Procharged Camaro SS. I already have LT4 in tank and JMS booster and 2 inch kooks headers. Dynoed 553whp 492 ft lb with that. Now i want more and ordered this...
GPI pistons n rods drop in package
WeaponX stage 1 Centri cam package 38% fuel lobe
LT4 Pump and injectors
Flexfuel
Now my question is where is the limit here fueling wise? Is it the injectors still?
Im considering upping my order with FIC 30% injectors instead. Goal would be 700whp but 650 isn't bad either for me.
Oh and the procharger is a P1SC. Thankful for any tip.
2SS A8 D1X Stage 2, 3.7 pulley, Kooks LT 2″, Borla XPIPE/ GPI drop ins,Caddy Racing Lifters, ATI Damper, LPE GT35 Cam 42%, LPE Big Bore, FIC 30% Injectors, Fore Twin intank pumps, Flexfuel, MM wild catchcan.
865 WHP 743 LB FT
2Forge 19" wheels daily, Forgestar D5 17" for track
Dennis 2ss is offline   Reply With Quote
Old 01-15-2022, 11:37 AM   #2
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
Looks like your pretty much on track and no what to upgrade next.
LT4 in the tank - check
Did you do LT4 high side pump?
LT4 injectors is a must.
You did the fuel line booster - check
I would consider doing the heads to complete the set up.
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
Old 01-15-2022, 12:00 PM   #3
MSU120
Drives: 2018 1SS 1LE
Flexfuel
Very close to my set up…..I had the heads done tho. I almost went with the FIC 30s but ended up not.
2018 SS 1LE—707rwhp, 615rwtq
2009 Pontiac G8 GT—605rwhp, SOLD
MSU120 is offline   Reply With Quote
Old 01-15-2022, 12:11 PM   #4
Dennis 2ss
Dennis 2ss's Avatar
High side LT4 is ordered and LT4 injectors. I will talk to my tuner about the heads. Might as well do them now when its opened up. Just wonder since im going E85 mix if the LT4 injectors are good enough or i should just have ordered FICs 30% extra Injectors?
865 WHP 743 LB FT
Old 01-15-2022, 12:13 PM   #5
Dennis 2ss
Dennis 2ss's Avatar
Yeah i could save the money and skip the FICs and just do the heads instead
865 WHP 743 LB FT
Old 01-15-2022, 12:20 PM   #6
MSU120
I’m at 7-8lbs of boost with the P1SC as well. What are the cam specs you’re looking at?
Old 01-15-2022, 12:24 PM   #7
BlackbeastSS2
If you have the cash get the better injectors that’s my thought but ask your tuner for sure. Let me know what he thinks, what’s the price for 8 of them?
Old 01-15-2022, 12:26 PM   #8
Dennis 2ss
Dennis 2ss's Avatar
Ok thats great numbers. WeaponX didn't give out specs on the cam, will see when i get it home. Its a sleepercam. Really don't know to much about it.
865 WHP 743 LB FT
Old 01-15-2022, 12:28 PM   #9
Dennis 2ss
Dennis 2ss's Avatar
$3200 so they are pricey plus i'm in Sweden so 32% extra with taxes bullsh.
865 WHP 743 LB FT
Old 01-15-2022, 12:28 PM   #10
LT1ornothing
Drives: 2020 LT1 M6
From my understanding, LT4 set up (hpfp, injectors, & intank pump) is good to high 600'rwhp on an ethanol blend. Adding a cam to that, I think that you can almost max out that p1sc.
Old 01-15-2022, 12:47 PM   #11
Dennis 2ss
Dennis 2ss's Avatar
yea its something like that. Hopefully the Cam will get me to 650 at least.
865 WHP 743 LB FT
Old 01-15-2022, 12:53 PM   #12
MSU120
For comparison purposes, my cam specs are:
Intake: 228 @ .050
Exhaust: 240 @ .050
Intake lift: .646”
Exhaust lift: .646”
Lobe separation: 116
Old 01-15-2022, 12:55 PM   #13
Dennis 2ss
Dennis 2ss's Avatar
Intake: 228 @ .050
Exhaust: 240 @ .050
Intake lift: .646”
Exhaust lift: .646”
Thanks bro.
865 WHP 743 LB FT
Old 01-15-2022, 02:32 PM   #14
ZO6Ted
Old badass
ZO6Ted's Avatar
Drives: 14GMC 2.9 16GMC Turbos 2020Silv.6.2
Last I checked Extreme XDI + 30's were 2500 when I last looked. I would do them for E. Best of luck.
ZO6Ted is offline   Reply With Quote
