Old 01-12-2022, 10:09 PM   #1
Kerry
Drives: 2019 2SS Camaro
315 35 20 Tires
Anyone running this size and if so whats the front size?
Kerry is offline   Reply With Quote
Old 01-15-2022, 09:00 AM   #2
Msquared
Msquared's Avatar
Drives: Chevrolet SS 1LE
That tire size is 28.7" in diameter, or 1" taller than the tallest tires the factory fits to any Camaro. I think it's likely to cause fitment issues.
Matt Miller
2020 SS 1LE
Msquared is offline   Reply With Quote
Old 01-15-2022, 10:42 AM   #3
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
On my 2016 Camaro SS I went with a taller tire when I got the car right at the start because it was winter and needed an all season tire. Every moderate bump/hump on the road would make the car bottomed out in the rear.
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
Old 01-15-2022, 10:58 AM   #4
Fraxum
Fraxum's Avatar
Agreed and if you match that with a taller 35 front tire it will rub in the front. I had this problem. I would try 30s. If you are looking for a 30 DR Nitto has one. I run them on my LT1 in the summer for more fun.
Old 01-18-2022, 09:37 PM   #5
WillyZ83
WillyZ83's Avatar
Drives: 18 zl1 garnet red
I’m running 315/30 on the rear and I would imagine the 35 would rub pretty much anytime you hit a significant bump. Mine is a 2021 1SS
WillyZ83 is offline   Reply With Quote
Old 01-18-2022, 10:42 PM   #6
cmeJATT
cmeJATT's Avatar
Drives: CAMARO
What’s the front size ?
cmeJATT is offline   Reply With Quote
Old 01-18-2022, 10:56 PM   #7
WillyZ83
WillyZ83's Avatar
275/35/20. The stock size the rear came with, I put in the front and I love the stance the car had now. Feels more planted in turns, and with the wider rear it gets better grip from a stop w aggressive throttle
Old 01-18-2022, 10:59 PM   #8
dpevans
Drives: 2024 Riverside Blue 2SS 1LE
https://support.apexraceparts.com/hc...-Fitment-Guide
dpevans is offline   Reply With Quote
Old 01-19-2022, 01:51 PM   #9
Fraxum
Fraxum's Avatar
I hope it is not rubbing like mine was. Check the inside of each front tire. I had to put a small spacer on.
Old 01-19-2022, 03:16 PM   #10
WillyZ83
WillyZ83's Avatar
thanks for the heads up, I'll check it out and see if it's rubbing on the inner edge.
Old 01-19-2022, 04:22 PM   #11
Sledgehammer70
Lethal Camaro
Sledgehammer70's Avatar
Drives: 16 2SS, 71 Std, Suburban RTS
It really comes down to the brand of tire and their size. some fit 315 35's no issue while others go 315 30. look at the diameter of the tire and get as close to the factory size as possible to avoid stabili-trac issues.
I ran 315/30 and 285/35 on my car when on street tires.
Sledgehammer70 is offline   Reply With Quote
Old 01-19-2022, 06:47 PM   #12
Isn't it because you have MRR wheels with a different offset than the OEM 1LE wheels?
Old 01-19-2022, 07:54 PM   #13
Wyzz Kydd
Drives: 2018 Camaro SS1 1LE
295/30/20 and 305/30/20.
Wyzz Kydd is offline   Reply With Quote
Old 01-20-2022, 09:47 AM   #14
FlukeSS
FlukeSS's Avatar
Drives: 2020 Camaro 2SS A10
Question: Any issues with the wire harness on the driver side? I was considering going to a 315 on the rears myself. I did research 315's and from what I saw it may require I believe a 5mm spacer is that how yours is setup?
