![]() Drives: 2018 Chevrolet Camaro 2SS Join Date: Jan 2022
Hi everyone,
I just picked up a 2018 Camaro 2SS 6-speed with only 6500 miles. Excellent condition, absolute steal of a deal I got. This didn't happen when I test drove the car, but I've noticed the last few days an issue with only 1st gear. If I floor the pedal in 1st gear, around 3,000 rpm the shifter will violently pop out of gear into neutral. 1st gear is otherwise completely fine with moderate to light acceleration and shifts into 2nd gear are very smooth, same with the rest of the gears. I can't imagine this transmission having issues already, so maybe there's something going on with some bushings? Maybe some parts on the shifter itself are loose? Has anyone heard of this or experienced this? That's my only issue with this car and transmission. Just baffling that a car with such low mileage would be doing something like this. Any comments, thoughts or suggestions would be greatly welcomed. Thanks! |
![]() Drives: 2017 2ss, m6 Join Date: Jan 2017
Is the transmission fluid fully up to operating temp when this is happening? These TR6060's get finicky during cold weather operation and I had mine pop out of both reverse and 1st on occasion when the transmission was cold. Bushing deflection would allow for a partial engagement. This happened right upon clutch take up though so it was different than what you are describing.
If your transmission will repeatedly come out of gear in 1st under heavy load that likely means the engagement teeth behind the synchronizer on 1st gear have been damaged. The teeth are shaped like a diamond so that they pull the engagement collar into the gear and ensure engagement. If they become damaged due to clutchless shifting they can lose their ability to hold the collar in the engaged position. If the transmission repeatedly fails to hold 1st gear when warm but engages 3rd and 5th without issue I would say that you have a damaged 1st gear or possibly a shift fork issue - both will require the transmission case to be opened up. |
#3 | |
![]() Drives: 23 1ss 1LE Join Date: Sep 2022
![]() Drives: 2022 2 SS 1LE on order ....now a 23 Join Date: Jan 2022
https://youtu.be/FxngwiF7_Wg This is enteresting.
![]() Drives: Camaro Zl1 Join Date: Jun 2023
Brutal mine pops out of reverse all the time and sometimes out of first, its annoying, most of the time ill hold it there so it can't pop out.. :P 2021 zl1 1le... the real question is ... why aren't they recalling them? I mean if they know the housings for these things are too small, why haven't they made 1 without the issue? Replacing it under warranty is not a solve to this issue as it will reoccur, if the new transmission's housing is still too small.........
