Old 01-11-2022, 11:29 AM   #1
fj5gtx
fj5gtx's Avatar
Drives: 70 GTX, 06 Mustang, 22 Camaro LT1
questions on the 2022 configuration 1SS or LT1
I'm considering buying a new Camaro... Have a few questions:
1. is the 1SS actually faster than the LT1? I'm seeing reports of 1/2 second 0-60 times faster with the 1SS. What makes that difference? Seems like same powertrain configuration and the LT1 is probably a little lighter. Doesn't seem to make sense.
2. Does the manual trans version include the cylinder deactivation feature? I'd like to avoid that feature.
3. Manual trans - I've seen a few reports of having issues with shifting and clutch on low mileage 1 year or newer cars. Is there something behind this, or just bad luck/hard use?
fj5gtx is offline   Reply With Quote
Old 01-11-2022, 01:03 PM   #2
LT1ornothing
Drives: 2020 LT1 M6
1. SS has a higher top speed and summer performance tires 275 wide stock. Lt1 has a 155 speed limiter because of all season 245 wide tires. LT1 is faster than an SS when you upgrade LT1 tires and remove LT1 speed limiter.
2. All LT1 and SS have the cylinder deactivation hardware from the factory regardless of auto or manual. The difference is that hardware is turned off on the manual cars.
3. I have had zero issues with my manual, shifts perfect. One of the best manual transmissions I have ever owned. I dont baby it, but I have over 20 years experience operating manual transmission in sports, muscle, trucks, sedans and econoboxes. The TR6060 transmission in this car is awesome.
Old 01-11-2022, 01:11 PM   #3
Callaway SC630
Callaway SC630's Avatar
Drives: 2020 Callaway Camaro SC630
Why is an LT1 faster?
2020 Callaway Camaro SC630 - MN6 1SS Satin Steel Gray
2019 Callaway Corvette SC757 - MN7 1LZ Elkhart Lake Blue
Callaway SC630 is offline   Reply With Quote
Old 01-11-2022, 01:14 PM   #4
LT1ornothing
Drives: 2020 LT1 M6
Power to weight ratio combined with a lower drag coefficient. The LT1 is more aerodynamic than the SS. Remember that the SS is a track car with oem track warranty, track cars require downforce.
Old 01-11-2022, 01:17 PM   #5
Callaway SC630
66 pound weight difference per Chevy? Spoiler?
So how much faster?
Old 01-11-2022, 01:20 PM   #6
LT1ornothing
Drives: 2020 LT1 M6
So how much faster?
All things equal, a tenth or two in the quarter mile, the gap will be much greater in the 1/2 mile or more when the downforce of the SS carries a higher burden than the LT1 with the better drag coefficient for top speed.
Old 01-11-2022, 01:21 PM   #7
Callaway SC630
Where can I see these numbers published?
Old 01-11-2022, 01:27 PM   #8
LT1ornothing
Drives: 2020 LT1 M6
You might find the weights and drag coefficients online, but you won't find anything regarding the LT1 being faster because only stock cars are ever compared. Stock, the SS is faster only because it has no speed limiter and better tires. Remove the LT1 speed limiter and put the same tires the SS comes with on an LT1 and voila, LT1 is faster than the SS.
Old 01-11-2022, 01:30 PM   #9
evilstevie
Drives: 2022 RBM 2SS 1le
GM states the weight difference between the two trims as about 65lbs. Good luck noticing that real world. I can't imagine the aero being measurably different in looking at both cars. As you already noticed the SS does test faster, likely due to better tires. They're the same car with the same motor, so of course are going to be about the same speed. The SS has a few more std features (and diff front end of course) which increases weight and price by a bit, that's about it. Both great trims.
2022 Camaro 2ss 1le RBM:
8/17/21 - Order placed to dealer
9/23/21 - Order placed by dealer with allocation
10/7/21 - 3000 status , TPW 11/15/21
12/3/21 - 3100 status , TPW 12/13/21
12/14/21 - 3400 status, TPW 12/13/21
01/07/22 - Built at some point in late December. Delivery to dealer scheduled for 01/30/22
Delivered to dealer on 2/1/2022
Drove home on 2/2/2022.
evilstevie is offline   Reply With Quote
Old 01-11-2022, 01:34 PM   #10
LT1ornothing
Drives: 2020 LT1 M6
Callaway, remember this is purely straight line stuff. The SS (and moreso, the 1LE) still rule on the road courses and leave the LT1 in the dust with their superior braking and additional downforce aiding in high speed turns.
Old 01-11-2022, 01:34 PM   #11
Callaway SC630
Nice escape from providing details.
To fj5gtx: Enjoy either that you choose.
Old 01-11-2022, 01:42 PM   #12
LT1ornothing
Drives: 2020 LT1 M6
The aero makes a big difference reaching top speeds, the LT1 would have an advantage over the SS as they approach top speed. Remember there are systems in place on the SS (front brake ducting, rear spoiler, etc creating an artificial air wall that slows the SS down at high speeds. These are non existent on the LT1 thereby allowing a lower drag coefficient which is favorable for top speed.
Maybe if you compare how much slower a 1LE is at top end compared to an SS, you will understand what I am trying to explain.
Old 01-11-2022, 01:43 PM   #13
LT1ornothing
Drives: 2020 LT1 M6
I did not avoid anything, you are just asking for my help to chew your food and help you swallow it.
Old 01-11-2022, 10:02 PM   #14
He11bent
He11bent's Avatar
Drives: 2019 2SS Convertible Camaro
Originally Posted by 1LEornothing View Post
All things equal, a tenth or tetwo in the quarter mile, the gap will be much greater in the 1/2 mile or more when the downforce of the SS carries a higher burden than the LT1 with the better drag coefficient for top speed.
I respectfully disagree. The 65 lbs may show up in the 3rd decimal on sheet of paper but wont make any difference on the track.
However, Launch controls, front brake locks, steering ratios, mag ride suspension, performance shifting, downward force in turns, brembo braking; Those are tangible in a race and the LT1 would be at a disadvantage.
Bottom line, OP. Buy what you like, no one will judge you. You can research the additional performance equipment as you go up the line from the LT1, 1SS, 2SS, +1LE, and ZL1. They are in that order for a reason.
\(^^^)/ <--A Smile From He11
Escort 360 MAXX w/DIYGen5 hardwire Harness
K&N AirCharger Cold Air Intake
Sound Tube Delete
He11bent is offline   Reply With Quote
