Old 01-01-2022, 03:16 PM   #1
PBnL
Drives: 2018 2SS 6 speed
6 Speed Shifter Issues
Hey Gang, I just traded a 15 1SS auto for an 18 2SS with a 6 speed. I'm an old 4 speed guy. Maybe I'm just out of practice but often when I shift from 1st to 2nd it goes to 4th. To prevent this from happening I try holding the shifter to the left during the shift. When I do that, it seems to hit a stop and I have to go back to neutral to pull it into 2nd. Is it just me or is that a common problem on a manual transmission?
It's driving me nuts because I want to take it to the dragstrip.
I'm not going to embarrass myself if I can't even shift it going to the friggin gas station.
Thanks Paul
PBnL is offline   Reply With Quote
Old 01-01-2022, 04:15 PM   #2
6spdhyperblue
Drives: 2SS 1LE
Skip shift for mpg
There’s a solenoid that does that to u when putting around
Old 01-01-2022, 04:18 PM   #3
MightyBobo
MightyBobo's Avatar
Drives: 2022 VOM 2SS 1LE M6 Camaro
It won't skip shift if you're giving it enough throttle and/or spinning the motor high enough. Shouldn't be an issue at the strip.
That, or order a skip-shift delete kit. Cheap and easy.
2022 Vivid Orange 2SS 1LE ordered (BDQDHT, 1G1FG1R7XN0108251)
20211120 - 1100 --- 20211207 - 2500
20211208 - 3000 (TPW: was 20220103, now 20220124)
20211220 - 3400 (TPW: 20220110)
20220114 - 3800 --- 20220122 - 4300 (1LE Wrap Shuffle)
20220125 - 4B00 --- 20220129 - 4200 (Shipped! ETA: 20220223)
20220212 - 4800 --- 20220216 - 6000!
2024 Silverado 1500 LTZ 3.0 diesel
MightyBobo is offline   Reply With Quote
Old 01-01-2022, 04:29 PM   #4
to the forums, PBnL, and congratulations on your upgrade
As stated above, this is a "feature" GM added for fuel economy, if you shift above 2500-ish rpm or give it more throttle, the "force 1st-to-4th shift" solenoid won't engage.
If I had the 6-speed Tremec, I'd get a skip shift delete harness on day 1 myself, that's for sure.
Old 01-01-2022, 04:31 PM   #5
MightyBobo
MightyBobo's Avatar
Btw, this "feature" has been around forever now. My old 2000 Z/28 had it lol.
Old 01-01-2022, 10:16 PM   #6
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
Just shift from first to second above 19 mph and you’ll not hit the skip shift lock out.
476 rwhp/440 rwtq (sold)
Old 01-01-2022, 11:49 PM   #7
UnknownJinX
UnknownJinX's Avatar
Drives: 19 Chevrolet Camaro 2SS 1LE Shock
As others said, it's a feature added to please EPA. It's not very hard to defeat with the right harness.
Or just give it more gas as you take off.
I personally never bothered adding the skip shift delete, but I see why some would consider it.
Also, read the Owner's Manual.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock
GM Performance Intake and that's it, because driver mods before car mods
Past:
2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold)
2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled)
UnknownJinX is offline   Reply With Quote
Old 01-07-2022, 11:26 PM   #8
Plasar
Drives: 2017 ZL1 Vert M6
Install a skip shift module…. $15 and 30 min effort
https://www.camaro6.com/forums/showp...4&postcount=15
Plasar is offline   Reply With Quote
Old 01-11-2022, 07:46 PM   #9
s346k
s346k's Avatar
Drives: like an old lady
yes, this feature has been on gm manual trans cars since the late 80s.
Old 09-25-2022, 10:48 AM   #10
camarofifty
camarofifty
Drives: 2017 Camaro Fifty
Skip-shift solenoid. Prevents 2nd gear engagement under pre defined perimeters. Enabled Camaro SS to achieve the magic 25 mpg epa number which kicks the gas guzzler tax out by going 1-4. Can be disabled very easily with “eliminator” plug in. I used to go 1-3 before I installed mine.
camarofifty is offline   Reply With Quote
Old 09-26-2022, 01:00 PM   #11
ctrlz
I agree. I would not even call this "aggressive" driving. You have to really be in a putt-putt mindset to hit the skip shift.
I daily drive this car, and the only time I get the skip shift is when someone at an intersection does something stupid and i have to slow down. maybe once every two months. I love gadgets and would have no problem installing the eliminator, but does not strike me as worth the effort.
I trained myself to go 1-3 when it comes up. Again, not a big deal.
Old 09-26-2022, 01:14 PM   #12
MightyBobo
MightyBobo's Avatar
Full disclosure: I did add the skip-shift solenoid to my car, as I've had one in every Chevy M6 I've owned for 19 years now.
That being said, the one in this Camaro was pretty unintrusive, and I found my normal driving prevented it from going off. On the occasion I was being pretty gentle, it'd hit and be annoying.
