Probably tired right now
Drives: 1Lap1LE | EV6 FE | DenaliHD | E92M3 Join Date: Sep 2010
Oil level sensor location and diagram
After a new motor install about 2 weeks, I got a low oil warning today and checked the dip stick and saw I was a little low (1/2 quart) but otherwise fine.
I put in the 1/2 quart and it still remains. I thought it was weird that the warning light would go on only a quart low (most vehicles I've ever had in the past need at least 1 full quart or typically more missing to throw the light) - And I checked the garage floor for leaks and didn't see any - So I started to get suspicious of the oil level sensor failing I did some internet searching and it looks like oil level sensors failing are somewhat common on the Gen6 Camaro. However I was unable to find a diagram of where it's located and where the plug for the sensor goes. Wondering how involved the job is. If anyone can point me to the diagram/pics/etc I'd appreciate it
'17 SS 1LE - 1LAP 1LE (Now with more 447!)
'24 Denali Ultimate 3500 DRW '22 Kia EV6 First Edition '12 E93 M3 '25 911 (ordered) Formers... '18 RS3 (1 of 2) Cumulus Blue | '19 RS5 Sportback Sonoma Green | '07 Cayman S 6MT | '16 Audi S3 Prestige Viper Green (APR Stage 3+) | '19 Mustang Shelby GT350R | '17 SS 1LE MBM 575whp all-motor |
![]() Drives: 2020 Chevrolet Camaro SS 1LE Join Date: Aug 2021
The oil level sensor is located in the oil pan and would require oil pan removal to replace the level sensor. The sensor has an integral harness with a pass through that is mounted in the right side of the oil pan(near the starter). I would first verify the connector from the engine harness is fully seated into that pass through connector in the oil pan.
See if this helps. This is for an LT1.
REPAIR INSTRUCTIONS - ON VEHICLE > ENGINE OIL LEVEL INDICATOR SWITCH REPLACEMENT > REMOVAL PROCEDURE 1. Remove the oil pan. Oil Pan Replacement . 2. Remove the crankshaft oil deflector. Oil Pan Disassemble . 3. Remove the engine oil level indicator switch bolts (1), retaining clip (2) and switch (3). DISCARD seal (4). 4. Oil Pan Cleaning and Inspection . Reassembly is the reverse, but with a new seal recommended. |
