![]() Drives: 2018 ZL1 Join Date: Jun 2020
HP Tuners Boost Question
Just got my HP Tuners working on my ZL1. Question to data log Boost, since the car reads boost now, can I just select the Boost/Vacuum channel to data log Boost only or do I have to do math with the Baro sensor??
I do see boost when recording but I don't see vacuum Thanks |
#2 | |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
This is different than Gauge Pressure which starts ate 14.7 PSIA which is Zero on the Gauge. Gauge pressure is only accurate at Sea Level since that is the baseline it uses as Zero. So log Barometric Pressure, then subtract this number from manifold absolute pressure and you will know what pressure above atmosphere you have. Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com |
thanks Ted!
Ted
when you have cars on your dyno , where do sample the AFR on the exhaust system ? |
We weld an O2 bung in the pipe before the cats.
thanks, seems like the passenger side may be a good location...
#7 | |
Ted.
#8 |
Thanks for the replies!!
