![]() Drives: 2018 Chevy Camaro 1LT Join Date: Jul 2021
Brake Light Wiring Help Non LED
I have the oem halogen brake lights, I want to tap into the turn signal, daytime running and brake light. Does anyone know or have a diagram of the wires for the brake lights? Any help would be greatly appreciated!
Here you go. Your car has the base signal paths, look for -T4F on the schematics (T4F is the uplevel HID/LED lighting RPO). Our US model does not have the T90 option either, that denotes the EU/Asia spec taillight plus rear fog light assembly, so again you need to trace -T90.
Hope this helps
#3 | |
This helps a little but I'm confused as to which is which because I can't read schematics. I'm trying to wire up break light, daytime running and turn signal lights.
#4 | |
Code:
BK Black BN Brown BU Blue GN Green GY Gray PK Pink RD Red VT Violet YE Yellow WH White
#5 | |
No I know that I just don't understand what I'm looking for on that diagram I see a Violet and white wire and a white and Violet wire. I just don't understand how to read the diagram to seek the specific colors I need which are the reverse light, brake light and turn signal on the 2018 halogen break lights.
| Tags |
| brake, lights, wiring |
