Old 12-22-2021, 12:04 AM   #1
TheTexanPunjabi
TheTexanPunjabi's Avatar
Drives: 22 ZL1 A10, 18 G90, 16 Taurus
Less than 600 miles and spot on the driveway.
Took out my Z earlier today and saw this in the garage floor. Looks like a combination of soot and condensation. Reckon anyone else experience this?
Order #ZWHXK5
08/16/21 - Placed order.
08/27/21 - 1100 status.
09/22/21 - 3000 status.
09/24/21 - 3000 status, 10/25 TPW.
10/05/21 - 3100 status, 10/25 TPW.
10/11/21 - 3400 status, 10/25 TPW.
10/28/21 - 3800 status. BUILT - 1G1FK1R68N0103958.
11/08/21 - 4200 status.
11/15/21 - 4800 status.
11/17/21 - 5000 status.
11/30/21 - Parked in my garage status.
TheTexanPunjabi is offline   Reply With Quote
Old 12-22-2021, 12:22 AM   #2
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
That's weird, fortunately doesn't look like oil...
Old 12-22-2021, 12:25 AM   #3
Sylv
Drives: 2021 zl1 1le
I just had to drop my camaro off for warranty today for an exhaust leak on the drivers side head/ exhasut manifold. It caked the entire plug and wire in soot along with the neighbor cylinders maybe you have a similar situation.
Sylv is offline   Reply With Quote
Old 12-22-2021, 01:28 AM   #4
SFV1LE
Drives: 2018 Hyper Blue ZL1 1LE
If it's under the exhaust, it looks like it may come from the holes where the muffler drains excess moisture and takes soot with it. If so it's normal. Check the bottom of muffler, you'll see the holes.
SFV1LE is offline   Reply With Quote
Old 12-22-2021, 03:22 AM   #5
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Normal.
The weep holes in the bottom of the suitcase muffler will drip black carbonaceous condensate.
Old 12-22-2021, 05:37 AM   #6
Firecaptain
Firecaptain's Avatar
Drives: '22 Summit White ZL1 A10
Normal.....exhaust piss......just marking its territory......
Firecaptain is offline   Reply With Quote
Old 12-22-2021, 06:43 AM   #7
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
Ya I agree it's exhaust and "normal", weep holes exist for a reason...unfortunately.
Old 12-22-2021, 06:49 AM   #8
hawk02
Coupe Newbie
hawk02's Avatar
I'll add to the list that says it's perfectly normal. You'll see it most when you haven't driven the car for awhile.
Old 12-22-2021, 08:04 AM   #9
Checkmate1
Drives: Garnet Red / ZL1 1LE
Normal. I have it too, our cars are tuned rich from the factory to protect the Cats. It's exhaust dribble. You are fine.
#SAVETHEMANUALS
Checkmate1 is offline   Reply With Quote
Old 12-22-2021, 09:00 AM   #10
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
My ZL1 does it too so like the above replies say it’s normal and nothing to worry about.
Old 12-22-2021, 10:20 AM   #11
Idaho2018GTPremium
Idaho2018GTPremium's Avatar
Drives: 2021 Camaro ZL1 A10
I would say it's normal only if it's coming from under the suitcase muffler, which has two holes to let excess moisture/condensate out. If it's from elsewhere under the car, then it is not normal.
When I wash my exhaust tips some water gets in the mufflers and it drains out somewhat through those holes.
2021 Camaro ZL1 A10
2022 GR Supra 3.0
Past:
2018 Mustang GT Premium w/ PP1, MR, and A10
2007 MazdaSpeed3
1995 Pontiac Trans Am
1987 Camaro Z28
Idaho2018GTPremium is offline   Reply With Quote
Old 12-22-2021, 10:33 AM   #12
PROMETHEUS
PROMETHEUS's Avatar
If that is under the exhaust tips......normal!
Old 12-22-2021, 11:09 AM   #13
Trochoidal
Drives: 2017 Camaro 2SS A8
This will be the source of your soot and condensation. As mentioned, if this is from the muffler area, it’s not weird and it is normal.
Old 12-22-2021, 11:17 AM   #14
SFV1LE
I sanded and sprayed some 303 anti-corrosion stuff around those holes, I assume muffler is made of aluminum or stainless or at least coated, but there was some light corrosion there from the water draining
