Old 12-18-2021, 04:41 AM   #1
ex-boxing champ
Drives: 2016 chevy camaro
How long before check engine light comes back on?
If I reset my check engine light codes on my car, how long or how many miles before the check engine light will come back again considering I dont actually fix the codes?
ex-boxing champ is offline   Reply With Quote
Old 12-18-2021, 08:59 AM   #2
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
That depends on what is causing the code. Some problems will trigger the MIL and set the code(s) immediately. What codes are you getting?
Old 12-18-2021, 11:27 AM   #3
ex-boxing champ
Im getting a P0711. Its to switch out the transmission temperature sensor.
Old 12-18-2021, 11:30 AM   #4
Blueclyde
Drives: 2023 ZLE
Probably two key/drive cycles if the malfunction is still present.
Blueclyde is offline   Reply With Quote
Old 12-18-2021, 11:41 AM   #5
ex-boxing champ
Ive driven over 300 miles now. Will that be enough?
Old 12-18-2021, 06:04 PM   #6
wavsine
________/\_
wavsine's Avatar
Drives: Gen6 NGM RS
Send a message via Yahoo to wavsine
It depends. If the trans temp sensor has totally stopped sending data, the check engine light will never go out. If it is sending data intermittently, then the check engine light will go off by itself after several start/stop cycles if the sensor has started working again. Scroll through the dash display and select trans temp. See if it is displaying a temp or just dashes, which means no data.
wavsine is offline   Reply With Quote
