12-17-2021, 11:32 AM | #1 |
Drives: 2011 LS V6 (M) & 2019 LS I4 (AT) Join Date: Jan 2015
PCV Replacement Hose
Does anyone know if this will fit the 2019 2.0T I want the mesh with the quick disconnect since I need to swap my catch cans out for smog.
It's the 2013-2018 PCV Replacement Hose. https://www.dallasgmparts.com/oem-pa...MaAvjSEALw_wcB
2011 Camaro LS (MT) - Vitesse Throttle Controller / Flowmaster 40 Mufflers / CAI Intake / Apex scoop and washer relocate / Epic Engineering Catch Can / SS Stoptech Brake lines / BMR 1.2" Lowering Springs / IPF tune /Magnaflow X-Pipe / 25mm Mace intake spacer / BBK Long Tube Headers with High Flow Cats
(Current) 2019 Camaro LS I4 - Vitesse Throttle Controller / Mishimoto intake boot and charge pipes / K&N panel / BMR Sway Bars / GFB DV+ / ZZP Larger Throttle Body |
12-17-2021, 12:44 PM | #2 |
Drives: 2014 Cadillac CTS4 2.0T Performance Join Date: Sep 2019
That is the 2016-2018 application that is NOT a quick disconnect at the valve cover valves.
If you cannot find a 2013-2015 hose setup that has the quick disconnects at the valve cover valves, then the second best you could do is to buy one of those and another set of PCV valves. Remove the "emissions bolts" at the valves and replace them with regular bolts, connect them to one of the y-pipes you just listed and swap out the whole assembly, valves and all when you need to go in for emissions. The only way that wouldn't work is if they physically check for those special "emissions bolts", but to do that they would need to pull the engine cover. |
12-17-2021, 01:03 PM | #3 |
Unfortunately I don't have an engine cover. My car didn't have one when I bought it. And I bought it with 34 miles. But that's an interesting idea with the assembly swap.
