![]() Drives: 2018 ZL1 Join Date: Jun 2020
HP Tuners Newbie
New to datalogging and HP Tuners,
I Just ordered HP Tuners and a AEM Wideband for my 2018 ZL1. Before I do any upgrades, I wanted to data log my current stock file, as its stock except for a green filter and ported TB. Is there a additional list of parameters I should data log besides the following:[LIST] RPM AFR Throttle Position Spark timing Knock Intake Temperature Map MAF Speed ??? Down the road when I do modifications, I'll have it tuned by a professional for sure, I'm just getting my feet wet with the data logging for now. Thanks |
Petro-sexual
Head over to HPTuners Gen V section. There are a whole lot more I'd add...
MAT ACCELERATOR PEDAL POSITION MPH ENGINE TQ PREDICTED TQ IMMEDIATE TQ BUSRT KNOCK KNOCK FOR ALL CYLINDERS GMVE O2s so many more, eventually You should search for Graphs to use, too. Also - try Goatrope Garage. He's got a good playlist of a lot of basic and some more advanced stuff. There are many ways to skin a cat, but he starts pretty easy to understand. It was easier to tune Gen III stuff in the past. Now - there are torque controls to blend in and there are still plenty of stuff we don't yet have access to. There's enough to get a car running well though. I'm not close to an expert or anything like that. There are plenty of helpful people though. You have to do the research, because you're not going to get all your answers in a post or thread.
Moderator
Agree with @radz28! Definitely add:
Desired fuel pressure Actual fuel pressure Commanded rail pressure Actual rail pressure Injector pulse width
There are several things you should log. Here are some off the top of my head.
Speed RPM Boost AFR AFR commanded Timing Fuel Pressures( low side / rail) KR Tq MGMT Advance Fuel Trims IPW and IDC MAF MAP IAT / MAT SOI Driver Demand Tq Delivered Engine Tq Engine Tq Peak Engine Tq Prdicted Engine Tq Commanded Throttle TPS TP IFR Coolant Temp Timing Cylinder Airmass O2 bank 1 &2 Trans gear
Petro-sexual
I run so many I’m on the verge of dropping PID values, lolz
Thanks all
Yes there are some great videos with GoatRope and HP's site. Question are the 02 sensors only there to monitor the cat's ? do they have any input on the tune itself ? I thought the tune was based primarily on the MAF and MAP info..and RPM , pedal etc... |
#7 | |
Moderator
