Old 12-10-2021, 09:31 PM   #1
Blobby
Drives: Former Owner '16 Camaro 2LT V6 conv
Car is dead and twitching. Bad alternator?
Yesterday the car was perfect. This evening I got in, everything was fine, went to start and it DIED. No attempt to crank, lights dim and flickering, kept getting worse, wipers started wiping incredibly slowly. Tried to jump under hood and no change. Tail lights and DRL stayed on constantly, dim, and flickering. Got the battery exposed and jumped from there. It tried to turn over but no joy. Electricals came back tho. Acted normal. All the lights turned off and I put the car to sleep for the night.
Auto parts guy says it’s probably alternator, but I think it’s obvious that satan himself has claimed this car. Any thoughts?
AGM battery two months old.
Hot start/ slow crank cable installed
2016 with 50k
Blobby is offline   Reply With Quote
Old 12-10-2021, 10:26 PM   #2
Nilly Welson
Drives: Camaro Super Sport, Six on the Stik
I think if it were the Alt. it would still start with a jump, it just would not charge the battery. Seems like a jump with a strong source would also start it. Could be a loose connection somewhere.
Nilly Welson is offline   Reply With Quote
Old 12-11-2021, 07:01 AM   #3
Spaceme1117
Spaceme1117's Avatar
Drives: 2017 Camaro SS, 2011 Corvette GS
Even though the battery is new most likely its bad.
Spaceme1117 is offline   Reply With Quote
Old 12-11-2021, 09:23 AM   #4
buck50
Drives: 2021 C8, 2022 Camaro 2SS
Time to have that new battery load tested! Your lowest cost first step.
Order 9/09/2021,2022 2SS, NPP, 56W whls, B04 stripe, AQJ seats, N26 strg. whl., SLN brace
3000 1/19/2022
3400 1/25/2022 TPW 1/31
3800 2/15/2022
4300 2/19/2022
4B00 3/04/2022
4000 3/8/2022
Delivered 3/9/2022
____________________________________
Order 6/01/2016 2017 2SS, NPP, 56R whls
3000 6/08/2016
3000 6/15/2016 TPW 7/18/2016
3400 7/7/2016
4200 7/25/2016
Delivered 7/28/2016
Sold May 2020
buck50 is offline   Reply With Quote
Old 12-11-2021, 09:28 AM   #5
Blobby
Here’s a question. If an older car we’re running, you could disconnect the battery or alternator and the car would be fine… until the battery died. What would the Camaro do under either of these situations? Can you push start a Camaro without a battery?
Old 12-11-2021, 12:12 PM   #6
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
No and No.
Do you have any aftermarket parts etc installed, ?
If alternator was defective your voltage would not go above 12.4.
Old 12-11-2021, 12:35 PM   #7
Blobby
Originally Posted by avalonandl View Post
No and No.
The dashboard volt meter has always hung out just under 14v most of the time and sometimes hovers around 12v. It’s done that since new.
I have a dash cam installed but it is powered only by switched power.
Old 12-11-2021, 12:37 PM   #8
That means the alternator is working properly, and if the meter does go down to ~12.5V periodically, the battery looks healthy, too. This gauge displays charging voltage when the alternator is charging the battery, and actual battery voltage when it isn't.
Old 12-12-2021, 10:46 AM   #9
wwiiavfan
Drives: 2017 1SS Hyper Blue
Yes, but not a definitive indicator to a good/bad battery. I had one that was less than a year old on my SS and acting like described. Dealer tested it twice and it passed, but they replaced it on their own dime and the problem went away and never came back.
wwiiavfan is offline   Reply With Quote
Old 12-12-2021, 12:01 PM   #10
Kerry
Drives: 2019 2SS Camaro
Most likley the battery is bad. If you have a good jump source and it wont jump with all the other symptoms of low voltage the battery is shorted and dragging down the system.
Kerry is offline   Reply With Quote
Old 12-13-2021, 10:22 AM   #11
ctrlz
Originally Posted by Kerry View Post
the battery is shorted...
Agree with all who say bad battery, and favor internal short as mode of failure.
You need to get a meter on this thing and see what's going on. Or just get the battery swapped under warranty.
Auto parts guy is probably thinking, "new battery, so that can't be it." I disagree.
Number of battery problems reported on camaro6 - dozens that I've seen.
Number of alternator problems (i.e. real problems, not the ones made up by someone who thinks his audio upgrade needs 8000 amps) - zero
Old 12-13-2021, 10:32 AM   #12
Blobby
The auto parts guy gave a disclaimer with his assessment. He said that a bad alternator caused similar symptoms on his truck, and since the battery is new, he’s “betting” that it’s the alternator. Need to bring it in for a test today.
Interesting note: the closest alternator was 150 mi away and closest starter was 4 states away. Thought this engine was more common than that.
Old 12-13-2021, 12:17 PM   #13
GONIF
GONIF's Avatar
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE
Just fully charge the battery and see if it's bad. Simple and free . Did you do a test on the battery after charging it ?
OLD GUY FLYING FAST AND LOW
GONIF is offline   Reply With Quote
Old 12-13-2021, 12:30 PM   #14
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Unlike flooded cell batteries, AGM batteries recharge VERY SLOWLY. Driving the car 1+ hr may not charge it fully. Ask me how I know. Get a proper AGM battery tender on the car. If you have excessive parasitic drain, an AGM tender might throw a false positive error. If so, disconnect the negative terminal and charge the battery directly with the tender without the car drawing power.
One of these can help avoid with this as well as avoid premature battery death due to parasitic drain if the car sits for extended periods. Just make sure you don't fully close the trunk after you disconnect the battery or you'll be popping the lid off the door handle to get back in.
