Old 12-10-2021, 07:22 AM   #1
Gbrownzl1
Drives: Zl1
Part 84212289 need asap
My rear driver side brake caliper is bad and I need a new one. The part is on back order and cannot be found. If anyone has a lead on a new or used one please let me know. Thank you in for helping. This is getting super frustrating.
Gbrownzl1 is offline   Reply With Quote
Old 12-10-2021, 08:35 AM   #2
cdb95z28
cdb95z28's Avatar
What is bad about it?
"KEEP THE FAITH"-Fbodfather
Old 12-10-2021, 08:44 AM   #3
sr71bb
sr71bb's Avatar
Drives: 2019 Camaro Z-28
Those calipers are rebuildable with new pistons and seal kits and those parts ARE readily available.
2019 SS 1LE BIG NA A10
Eagles Canyon Raceway 2.7 CCW Below
https://youtu.be/c9M5UHDftcA
4-15-23 at SCCA TT U1 Class
MEGA Thread on THIS car:
https://www.camaro6.com/forums/showthread.php?t=602092
Retired Cars BELOW:
1973 Camaro, 1969 Camaro, 1969 Camaro SS RS
2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10
sr71bb is offline   Reply With Quote
Old 12-10-2021, 09:36 AM   #4
Gbrownzl1
Drives: Zl1
The part circled is the broken part. They are saying I have to replace the whole caliper and can't replace just that part
Old 12-10-2021, 10:01 AM   #5
infinitereality
Limitless Imagination
infinitereality's Avatar
Drives: 2018 ZL1 & 2022 Hayabusa
I've been through this, trying to locate a crossover tube for the Gen5 SS Brembos, Brembo does not sell individually. You have to get a used/new caliper and swap it over. If I was you, I'd leave caliper mounted, remove the current cross over (or one off another one if it's bent to crap) and bring to a local speed shop. They will be able to easily bend you up one.
2018 Camaro ZL1 - Black
- OEM Options: A10, Exposed Carbon, PVR, Nav, No Sunroof
- Lightly Tinted GM Dark Tails, DD Side Markers, Morimoto 5000k, 100% LED
- RotoFab Dry, Forgestar CF5V (ZLE Spec), Eibach Pro, AeroForce Interceptor, GT4 Tow Hook
- Carbon Fiber (Satin): Radio, Shifter, Steering Wheel Controls, Shifter Top, AC Vents, Side Mirrors & Shark Fin
2022 Suzuki Hayabusa - Brilliant White Pearl & Shocker Yellow Wheels
- +4 Arm, 240 OEM Wheel, Brock's CT (Ti) Exhaust, 1.25" drop, etc...
infinitereality is offline   Reply With Quote
Old 12-10-2021, 10:09 AM   #6
Gbrownzl1
Drives: Zl1
That's a great idea. Thanks man
Old 12-10-2021, 12:02 PM   #7
cdb95z28
cdb95z28's Avatar
A rear caliper off a 2010-15 SS or ZL1, I believe, is the same, except for color. A 13-15 SS 1LE rear caliper is also red. Disregarding the color, the crossover is the same and you could just paint it to match then install.
I had a '14 SS 1LE and I know that the rear pads on that car were the same pad shape # as the Gen6 ZL1/ZLE. The calipers in the above picture look exactly like my '14 did except for the lettering.
That opens up your choices and will possibly be less expensive.
Old 12-10-2021, 12:08 PM   #8
cdb95z28
cdb95z28's Avatar
Rockauto has calipers in stock
Old 12-11-2021, 12:51 AM   #9
Gbrownzl1
Drives: Zl1
I checked rock and they put me on the wait list.
Old 12-11-2021, 12:51 AM   #10
Gbrownzl1
Drives: Zl1
@cdb thanks for that. I will find that dang tube if it's the last thing I do.
Old 12-11-2021, 12:53 AM   #11
Gbrownzl1
Drives: Zl1
Here's the damage
Old 12-11-2021, 12:54 AM   #12
Gbrownzl1
Drives: Zl1
Damage
Old 12-11-2021, 11:42 AM   #13
FrostZ
FrostZ's Avatar
Drives: 2019 A10 ZL1
Shoot me a pm I have a silver ZL1 rear driver caliper brand new I don’t need!
Morimoto Headlights, AWE Touring Catback, MM Catch Can, ADM V2 Reservoir, Roto-Fab, C&R Oil Cooler, 1LE Grills
FrostZ is offline   Reply With Quote
Old 12-12-2021, 09:34 AM   #14
Wuiquen
Wuiquen's Avatar
Drives: 2018 Hot Red ZL1
Damage
May I ask how the damage happened?
Sent from my moto g(7) power using Tapatalk
