Old 12-08-2021, 08:56 AM   #1
CW3SF
CW3SF's Avatar
Drives: 2019 Chevy Camaro ZL1 M6
Aftermarket injector selection
I’m pricing +30% injectors and I’m seeing FIC and XDI brands. There’s about a $400 difference in the two and both are a bit in the pricey side lol. Is either brand better than the other? Anyone know the differences in the two brands?
CW3SF is offline   Reply With Quote
Old 12-08-2021, 01:48 PM   #2
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
If you haven't, perhaps you might find more input over on HPTuners. There might be some useful stuff there, too.
'20 ZL1 Black "Fury"
Old 12-08-2021, 01:49 PM   #3
CW3SF
CW3SF's Avatar
Funny you should mention that, I was just over there reading.
Old 12-08-2021, 01:55 PM   #4
Z OH 6
Drives: 2024 CT5-V Blackwing
Never used XDI but Fuel Injector Connection (not to be confused with Fuel Injector Clinic) is spotty.
Old 12-08-2021, 02:46 PM   #5
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Out of my own curiosity - why are you going with this route? I haven't done the maths, but, is PI about the same or less? I know tuning is more complicated with adding PI, but I'm just curious.
Old 12-08-2021, 03:04 PM   #6
CW3SF
CW3SF's Avatar
I’m upgrading ported oem TB to 103, standard Rotofab to Big Gulp and Stage X porting the stock blower. That’s gonna pretty much kill my ethanol content due to injector PW. I’m looking at doing the +30 injectors while the blower is off to gain PW headroom and add ethanol back in to the mix. My research says that the stock fuel pump with JMS booster will support the +30s and I’ll be under 725whp, so my high side should also be good. Staying with stock pulleys.
Old 12-09-2021, 06:34 AM   #7
ZLE dude
Drives: '18 ZL1 1LE
I'm curious to see how this turns out. I do love running E!
2018 ZL1 1LE - Summit White, PDR, Rotofab CAI, 95mm TB, CSP 2" catless LT's, JMS Voltage Booster, AEM X-series WB, DSX flex fuel sensor, Banks Data Monster, Tuned by Ted Jannetty, 5% Tint, Blackvue DR900S-2CH, Diode Dynamics lighting, IGL Kenzo ceramic coating
ZLE dude is offline   Reply With Quote
Old 12-09-2021, 07:36 AM   #8
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Thanks for the response. I learn something every day
Old 12-09-2021, 08:36 AM   #9
JANNETTYRACING
JANNETTYRACING's Avatar
I have FIC 30% over in stock if that helps you.
You will run out of high side pump next.
Ted.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 12-09-2021, 08:40 AM   #10
CW3SF
CW3SF's Avatar
Ted.
Thanks Ted. I’ll be in touch. Appreciate it.
Old 12-09-2021, 09:15 AM   #11
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
The FIC's seem to be hit or miss...you either get a good set or get a set that has issues. A friend of mine put a set in his Turbo SS and they were causing weird issues with part throttle fueling. FIC sent him another set and they were fine. GPI told him that they have had seen this happen a few times. I haven't heard or read any negative reports on the XDI yet.
Old 12-09-2021, 09:24 AM   #12
CW3SF
CW3SF's Avatar
Thanks for the input. The XDIs seem to be running about $400 less than FIC also.
Old 12-09-2021, 09:27 AM   #13
KingLT1
KingLT1's Avatar
Not if you know where to look....FIC are the cheapest.
Old 12-09-2021, 11:18 AM   #14
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Your currently holding 75-80psi low side and 2900 high side now?
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
