Old 12-06-2021, 12:28 PM   #1
KamZL1
KamZL1's Avatar
Drives: Z06
Service History
Well after reading oil pump failure thread, i kinda scared the hell out of myself and was wondering what is the easiest way to get service history record for my car? can I just go to any dealership and ask for it? Also, the car has 31,xxx on it now, should i even be worried if something hasn't happened yet? should i be including katech pump when i do my first mods? thanks
KamZL1 is offline   Reply With Quote
Old 12-06-2021, 01:33 PM   #2
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
did you buy new or used?
Old 12-06-2021, 01:38 PM   #3
KamZL1
KamZL1's Avatar
Drives: Z06
used
Old 12-06-2021, 01:44 PM   #4
10mm
Drives: My wife nuts...
Hit up any service Sept.
Should be in their system.
10mm is offline   Reply With Quote
Old 12-06-2021, 01:56 PM   #5
KamZL1
KamZL1's Avatar
Drives: Z06
Guess the one place I called is clueless; said they would only have records of service performed at that specific dealership and couldn't access anything else
Old 12-06-2021, 02:16 PM   #6
hotlap
hotlap's Avatar
If the service wasn't performed at a GM dealership, there is no way they would know.
Ronald Reagan -
Old 12-06-2021, 02:19 PM   #7
KamZL1
KamZL1's Avatar
Drives: Z06
I assume the only place they would replace an oil pump would be at a gm dealership due to complexity and car still under powertrain. I just want a record of all services done to it, to see if it was replaced or not. according to this dealership i called here, there is no gm dealer database that they can access? pretty sure she was blowing smoke up my ass
Old 12-06-2021, 05:44 PM   #8
ihada69L78
ihada69L78's Avatar
Drives: 2023 Silverado LTZ, 2022 Camaro 2SS
There is a difference between blowing smoke and being ignorant/stupid.
Same result 🤦*♂️🤦*♂️
Currenent rides:
2020 SW ZL1 A10
2019 SW 2SS A10
2017 SW Silverado LTZ
ihada69L78 is offline   Reply With Quote
Old 12-06-2021, 08:05 PM   #9
Vigilante375
Drives: 2018 Camaro ZL1
Repair work can be done anywhere, not just at the dealership.
Of course if it's still under warranty, it's a no brainer to get it done at the dealership.
Old 12-07-2021, 10:07 AM   #10
flatrockguy
flatrockguy's Avatar
Drives: 2015 Black ZL1 m6, gone 2012 CTS-V
PM me the vin and I will run it
2021-ZL1, Black, 6spd ceramic coated
2019-CTS-V, Black Gone
2015-ZL1, Black 6spd, CAI, JRE 75rwhp Gone
2012-CTS-V, Black 6spd Gone
flatrockguy is offline   Reply With Quote
Old 12-07-2021, 10:30 AM   #11
semif18
Drives: 2018 ZL1 1LE White
Maybe I'm alone in this but I think the oil pump issue has been overblown.........if you look at the total number of cars built and the # of pump failures actually documented on this website, despite the fact that obviously not all ZL1 owners are on here, it feels like it's actually a small percentage. Nobody really knows what the actual failure rate is. Based on my build date I'm after the majority of the failures listed here, but even if it wasn't I'm gonna keep driving it hard and if it fails it gets fixed under warranty. But I get it.......when folks read the stories on here and others pile on with "Yep, there's an issue with oil pumps, beware!" it freaks people out. The Z06 heat soak issue was documented by more than just the forums. I don't know of any publications that have run a story about supposed ZL1 oil pump issues. If that happens then I'd start to think more about it.
semif18 is offline   Reply With Quote
