Black lightning
Package consideration
Okay, I've been going over packages etc etc and came up with this how do you guys like it possible hp gains? No pulley upgrade due to heat soak issues.
Rf Big Gulp Kong X ported SC 103 TB Lt Headers E50 Jms booster Trans tune.
[ 2021 Camaro ZLE 10 speed
![]() ![]() ![]() ![]() Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
Yes. You’ll need to add a JMS Booster to run e40-e50. Will be a killer set up with 675-700whp with no additional heat soak issues. I’d also do ceramic coating on the headers to reduce under hood temps.
Black lightning
JMS booster Really?? I've never heard of that being needed to E 40/50
You wouldn’t if you had no mods. You listed headers, 103TB, Big Gulp and ported blower. Each and every one of those mods reduce the amount of ethanol that your fuel system can support. You can offset the reduction in the amount of ethanol by JMS, aux low side pump or new cam. JMS is easiest of those. High side fuel will be good till about 700-725whp
#5 | |
Black lightning
![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL1 Join Date: Mar 2019
Your going to make more boost even with stock pulleys with the X port. You won’t be able to run E50.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
#7 |
Should be a solid package. I just tuned my brothers A10 ZL1 with Headers, CAI, ported 95mm tb, flex fuel. It is making right at 10psi peak. Has enough fuel for E52 targeting .84 Lambda. X port will likely change that as others have mentioned.
#8 |
Oh Oh it's Friday Night!
Drives: 2018 ZL1 1LE Nightfall Gray Join Date: Jan 2018
I dont think you’ll need a Big Gulp. The regular roto fab is good until 750 HP or so.
Four that wanna own me Two that wanna stone me One says she's a friend of mine... |
#9 |
#10 |
Black lightning
I no you get more hp from the big gulp and definitely more air.
#11 |
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
Go with the Big Gulp even if only because you might decide on more extensive mods later down the road. In that case you wouldn't be in the position of having lost money buying a regular intake and then reselling it used and now having to buy a BG. Plus with the Holidays around the corner now's the time to buy everything you think you're gonna want and need.
#12 | |
Black lightning
It's not on my original list but it was suggested by another OP
#13 | |
Black lightning
#14 |
With your list of mods you'll be much faster than you are stock. It is a worthwhile venture if you're getting it all at a good price.
