Old 12-01-2021, 03:16 AM   #1
TurnPikeSpike
TurnPikeSpike's Avatar
Drives: *2014 SS 1LE* 2019 Camaro ZL1/1LE
19' ZL1/1LE Headers, Lower Pulley, Mamo TB
Gentleman, I just wanted to post the numbers and get a little feedback on the most recent bolt ons. I had intended to cam it this time around but the wife needed a new Tahoe
1st pull had some tire spin down low so that was adjusted.
2nd pull seeing a little knock across the pull.
knock sensor left side most likely false knock
Final pull adjusted timing a little made 650whp/690wtq
Added 1/2 can BOOSTane put timing back in and ended at 677whp/730wtq
Parts List:
DSX LSA/LT4 240mm LT4 17%
ATI LT4 Balancer
NGK 6510 plugs
MSD 8.5mm wires
Kooks 2in Headers
Tony Mamo TB V2
Name:  BaseLine Dyno .jpg
Name:  1ST Dyno .jpg
Name:  2nd Pull .jpg
Name:  Final Dyno .jpg
TurnPikeSpike is offline   Reply With Quote
Old 12-01-2021, 03:38 AM   #2
TurnPikeSpike
Old 12-01-2021, 04:38 AM   #3
jaybee924
Drives: R.I.P. 2021 ZL1 & 2019 Rd Garn 2SS
What was the stock numbers?
jaybee924 is offline   Reply With Quote
Old 12-01-2021, 05:58 AM   #4
TurnPikeSpike
The First Dyno sheet is the baseline. 601whp/603wtq
Old 12-01-2021, 07:04 AM   #5
Z OH 6
Drives: 2021 Red Hot ZL1
A10 or M6?
Old 12-01-2021, 07:06 AM   #6
Z OH 6
Numbers look right to me. Mine made 697whp on 93 octane using the same pulley but I also have a Kong ported blower and 103mm TB and Kooks Green cats, not sure if you're still running cats or not.
Old 12-01-2021, 07:22 AM   #7
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
I’d suggest dumping the Mamo TB in favor of a 95mm at least (or 103mm).
Old 12-01-2021, 07:26 AM   #8
Z OH 6
Agree here if he installs a ported blower but if he still has the stock blower, the inlet will be a restriction beyond 95mm.
Old 12-01-2021, 09:16 AM   #9
KamZL1
KamZL1's Avatar
Drives: Z06
nice man, planning on doing this exact same thing soon; these numbers were exactly what i was looking for (actually more)
any cooling mods done? and why boostane instead of a little e to get rid of the knock?
Thanks
KamZL1 is offline   Reply With Quote
Old 12-01-2021, 09:21 AM   #10
KamZL1
KamZL1's Avatar
Drives: Z06
Agree here if he installs a ported blower but if he still has the stock blower, the inlet will be a restriction.
so no point in going 103 until blower is ported or bigger blower?
Old 12-01-2021, 09:25 AM   #11
Z OH 6
The problem is that stock blower inlet is only 95mm if I recall so going larger wouldn't help much without opening the snout to match up to a larger TB.
Old 12-01-2021, 10:52 AM   #12
TurnPikeSpike
A10 or M6?
M6
No cooling mods at the moment and the i didn't want to run E and the shop suggested the BOOST so i tried it out. Im in Iraq so I don't even know how it drives yet.
Old 12-01-2021, 11:39 AM   #13
Z OH 6
Originally Posted by TurnPikeSpike View Post
M6
I have AFCO heat exchangers installed in mine with that pulley setup.
Old 12-01-2021, 11:55 AM   #14
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Stock? That’s very high if stock. I’ve seen some 560-570 in very cold weather dynos but never 600.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
