Old 11-29-2021, 10:22 PM   #1
Husker67
Husker67's Avatar
Drives: '22 Camaro 2SS 1LE Wild Cherry
Catch Cans??
I remember when I had my '16 SS reading about this subject. What do you guys think about these? Need One??? Or just another hassle??
Husker67 is offline   Reply With Quote
Old 11-29-2021, 10:24 PM   #2
KyBoy
KyBoy's Avatar
Drives: '17 2SS H50
I think of a catch can like a gun. I'd rather have it and not need it vs need it and not have it.
We can see too far.
1100 - 5/26
0000 - Cancelled - 7/5
Contacted Becky - 7/1
2000 - 7/5
3000 - 7/6
3000 - 7/11 TPW 8/1
3100 - 7/18 TPW 8/1
3300 - 7/20
3400 - 7/21
4300 - 8/3
5000 - 8/5
6000 - 8/13
Old 11-30-2021, 05:29 AM   #3
Spaceme1117
Spaceme1117's Avatar
Drives: 2017 Camaro SS, 2011 Corvette GS
Not a bad idea to have one. But the LT1 engine seems to not build up deposits on the back of the intake valves nowhere near as bad as other DI engines.
Spaceme1117 is offline   Reply With Quote
Old 11-30-2021, 06:30 AM   #4
jamala00
jamala00's Avatar
Drives: 2016 Camaro 2SS Hyper Blue Metallic
No catch can here. Not needed.
jamala00 is offline   Reply With Quote
Old 11-30-2021, 06:56 AM   #5
Drags1998
Drives: 15 SilveradoLTZ,162SSVert BlazerRS
IMHO its Not needed, I liked the GUN Idea!!!! It just seems to Me That There is alot of Expensive JUNK out there that is NOT NEEDED!!!! ( I am not calling out the Catchcan Makers) I'm talking the Whole Aftermarket Industry. They do a great job of selling us Sub par Products,AND We buy it!!!!
Drags1998 is offline   Reply With Quote
Old 11-30-2021, 07:35 AM   #6
SJFGTO
Oh Oh it's Friday Night!
SJFGTO's Avatar
Drives: 2018 ZL1 1LE Nightfall Gray
Tons of threads on this. All the pros and cons are discussed and debated over and over. Do they work? Yes. Do you need one? No. I have one, ran one on my LS2 GTO as well. Always a couple table spoons of oil and impurities in the can every time I change the oil. Nice to see, but you can live without it.
Four that wanna own me
Two that wanna stone me
One says she's a friend of mine...
SJFGTO is offline   Reply With Quote
Old 11-30-2021, 07:36 AM   #7
Nothing like an SS
Faster!!!
Nothing like an SS's Avatar
Drives: 2020 Camaro 1SS 1LE
No, you don't need one.
Nothing like an SS is offline   Reply With Quote
Old 11-30-2021, 07:37 AM   #8
hotlap
hotlap's Avatar
Not needed.
The LT1 has been in production since 2014 and photos of high mileage engines show that the valves are ~clean.
A catch-can can/will void your warranty. If not properly maintained, it will impede crankcase ventilation. The issue of the can filling, and preventing ventilation, is amplified in cold climates because the can will fill with condensation in one weeks time. I had this happen on my 16 and the oil became loaded to the point that my eyes burned when I drained it. Never again
Ronald Reagan -
Old 11-30-2021, 08:02 AM   #9
dmcmahan60
dmcmahan60's Avatar
Drives: 2017 SS
In the end , it is your car and investment. if it gives you piece of mind for a couple hundred dollars then do what you feel is right to you.
dmcmahan60 is offline   Reply With Quote
Old 11-30-2021, 10:15 AM   #10
SSlow6
SSlow6's Avatar
Drives: '11 BMW 328i, '22 2SS 1LE
I understand the reasoning for catch cans, but if they were so beneficial I always thought that OEMs would starting putting them on their engines.
SSlow6 is offline   Reply With Quote
Old 11-30-2021, 10:29 AM   #11
This was discussed ad nauseam also. It would add another regular maintenance item that, when forgotten by the average user, could result in disaster. Also, if it's only beneficial for you, the customer, in extending your engine life and not reducing your performance post powertrain warranty, manufacturers wouldn't care much, would they. We are talking about GM that still uses halogen turn signal/reverse bulbs and refuses to install auto dimming on the passenger side mirror just to save a few pennies.
Old 11-30-2021, 11:55 AM   #12
L78toLT1
L78toLT1's Avatar
I've had the heads off of my motor at 16k and 33k miles. The deposits on the valves were noticeable, but not bad at 16k miles without a catch can - I've posted photos on several other catch can threads. The valves are noticeably cleaner after 17k miles with the can. It should be noted that the can was installed when I added the cam and blower, which should accelerate the formation of deposits.
As many have stated, the can is not a requirement, but it definitely does reduce the accumulation of deposits on the intake valves, which to many justifies the cost and the minor hassle of maintaining the can.
Baby Blue
Old 11-30-2021, 12:17 PM   #13
zxspeedspec
Drives: Faster than yours
I would rather they cheap out a few pennies here and there and get a 650 horsepower package for $63,000. Ever think why they're the only manufacturer able to do this? Intelligent accounting practices and knowing where to "save a few pennies".
zxspeedspec is offline   Reply With Quote
Old 11-30-2021, 12:34 PM   #14
SSUNDVL
Drives: 2016 Camaro SS
I had a lot of gunk on my valves when r&r the heads, was a pain to clean and put catch can on after. If you are FI you should have a catch can, small expense and reduces oil in the combustion process.
SSUNDVL is offline   Reply With Quote
