Old 11-28-2021, 09:34 PM   #1
Web9
Web9's Avatar
Drives: 2018 Camaro ZL1 1LE
ZL1 1LE Brake rotor min thickness?
Can someone confirm the minimum (discard) thickness for the front and rear OEM rotors? Thanks.
Web9 is offline   Reply With Quote
Old 11-28-2021, 10:15 PM   #2
Here you go:
Old 11-29-2021, 09:41 AM   #3
Web9
Web9's Avatar
Awesome. Thanks!
Old 09-13-2022, 08:34 PM   #4
wakespeak
wakespeak's Avatar
Drives: 2020 ZL1 1LE
34.5mm front after about 3k track miles.
wakespeak is offline   Reply With Quote
Old 09-13-2022, 09:14 PM   #5
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
no one is going to machine them these days so replace if they appear questionable (severely cracked or warped)
Old 09-14-2022, 08:25 AM   #6
Vigilante375
FYI to those that will replace the rotors. The front and rear caliper mounting bolts are TTY. You can go to a website called screamin chicken and buy the front and rear bolts (together) for $30. Those are reusable and are as good as the OEM ones.
Old 09-14-2022, 08:37 AM   #7
Zl1+911
Drives: 997 GTS, ZL1 A10, ZLEM6, ZLEA10
very helpful information. Would you mind providing a link to the product page for easy reference? thanks a lot
Zl1+911 is offline   Reply With Quote
Old 09-14-2022, 09:00 AM   #8
MatthewAMEL
MatthewAMEL's Avatar
Anyone have the updated, 2022+ manual with the BCD brakes listed?
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
2025 Hysteria Purple
C8 Z07
Old 09-14-2022, 09:10 AM   #9
cdb95z28
cdb95z28's Avatar
The caliper bolts are torque to angle, not torque to yield. They are not one time use and the service manual says they are reusable with high temp/high strength threadlocker.
BRAKE CALIPER FRONT J6H.pdf
BRAKE SYSTEM FASTENER TORQUE SPECS.pdf
"KEEP THE FAITH"-Fbodfather
cdb95z28 is online now   Reply With Quote
Old 09-14-2022, 09:18 AM   #10
cdb95z28
cdb95z28's Avatar
I looked at the service manual via AC Delco TDS back in January by using my BCD equipped VIN, and the manual was not updated to show the BCD front rotor specs.
Old 09-14-2022, 09:23 AM   #11
RamAir02
Shadow Gray '19 ZLE M6
RamAir02's Avatar
Drives: '19 ZL1 1LE M6
Attachment 1108799
Attachment 1108800
Sorry to hijack the thread, but may I ask what service manual this is from? Is it the ACDelco TDS subscription? I still can't believe Helm doesn't have a 2019 service manual available yet.
YouTube
Old 09-14-2022, 09:28 AM   #12
cdb95z28
cdb95z28's Avatar
Yep, I looked at getting a print service manual and found what you did. Go here:
https://www.acdelcotds.com/subscriptions
I bought a 3 day subscription to the GM service manuals, I downloaded over 1200 pages for my '22 Camaro and my 3 other vehicles. It's $22 for 3 day access.
Old 09-14-2022, 11:54 AM   #13
Vigilante375
Attachment 1108799
Attachment 1108800
Thanks for that.. As far as I knew, they were TTY. But TTA are reusable, to a point.
