Old 11-23-2021, 08:46 AM   #1
Zaqwert6
Zaqwert6's Avatar
Drives: 2SS
To the NON daily drivers, how much gas do you keep in the tank?
What it says....
Mostly wondering about car that sits more than it's driven requiring premium fuel.
Zaqwert6 is offline   Reply With Quote
Old 11-23-2021, 08:52 AM   #2
LeonardS
Full and fuel stabilizer in every fill up.
Old 11-23-2021, 08:52 AM   #3
I try to fill up once the gauge reaches 1/4, and almost always do it by the time it reads 1/8. Had the low fuel light come on only once in 3 years.
Old 11-23-2021, 08:59 AM   #4
KyBoy
KyBoy's Avatar
Drives: '17 2SS H50
Half to full. Never been below half a tank. I've owned her since 5 miles on the odometer. I will throw a bottle of stabilizer in her this winter. Doesn't sit longer than a month without being driven.
We can see too far.
1100 - 5/26
0000 - Cancelled - 7/5
Contacted Becky - 7/1
2000 - 7/5
3000 - 7/6
3000 - 7/11 TPW 8/1
3100 - 7/18 TPW 8/1
3300 - 7/20
3400 - 7/21
4300 - 8/3
5000 - 8/5
6000 - 8/13
Old 11-23-2021, 09:05 AM   #5
jamala00
jamala00's Avatar
Drives: 2016 Camaro 2SS Hyper Blue Metallic
I don't keep any particular amount of gas in the tank at any given time except winter storage. (Full with Stable additive). When I do put gas in, it's always a full tank. That goes for any of my vehicles.
jamala00 is offline   Reply With Quote
Old 11-23-2021, 09:14 AM   #6
sengli
sengli's Avatar
Drives: 2015commemorative vert 2SS
Usually try to keep it full, and plugged into a battery tender
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded
2015 commemorative vert 2ss
sengli is offline   Reply With Quote
Old 11-23-2021, 09:23 AM   #7
95 imp
Dumb Ass Deluxe
I usually fill up when I'm a little below half so I can keep the 10:1 ratio for the octane boost.
I dive mine one a week usually. For long term storage you want a full tank to prevent condensation and a stabilizer additive.
Old 11-23-2021, 09:30 AM   #8
Zr8000
Drives: Chevy Camaro
I run non ethanol fuel and put fresh gas in it every time I drive it. For the winter I will dump a bottle of k100 in it
Zr8000 is offline   Reply With Quote
Old 11-23-2021, 09:41 AM   #9
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
I drive mine about once a week - maybe twice. I fill up when between 3/8 - 1/2. I don't bother with fuel stabilizer. I fill up with Costco 93. They have such high volume their fuel is always fresh.
476 rwhp/440 rwtq (sold)
Old 11-23-2021, 10:34 AM   #10
s346k
s346k's Avatar
Drives: like an old lady
no dd but it gets driven a lot. i typically fill it up (ethanol) at least once a week(end) unless the weather doesn't cooperate. during winter i'll fill it up with gas in late november usually and it'll sit on full until mid march.
Old 11-23-2021, 01:14 PM   #11
wingchunsifu
wingchunsifu's Avatar
Drives: 2017 2SS A8, 2026 BMW X1 M35i
To me, half equals empty...so full. We are always one news story away from gas lines.
wingchunsifu is offline   Reply With Quote
Old 11-23-2021, 07:56 PM   #12
GTO_Gregory
GTO_Gregory's Avatar
Drives: 2016 Camaro
I live in Texas, so there are more good days in the year for driving than Northern climates.
I run E85 99% of the time. Because there are times when E85 is difficult to find I never go below a third tank. Then there's always five gallons stored in the shed that gets rotated every few months.
I also have a GTO that's stored in the garage. It's E85 exclusive and I use the electric fuel pump to drain it the best I can. There's a fuse on the fuse block that can be jumped to run the electric fuel pump as desired.
2024 Chevrolet 3500HD Z71, LTZ, 4x4, 6.6 ltr. L5P long-bed.
2016 Camaro 2SS Six-speed, Hotchkis sway bars, Eibach .750" drop springs, Mamo throttle body, E85, BMR stuff.
2006 Quicksilver 6-speed GTO ERL LS3-430, All-Pro 285cc heads, 262/273 .758/.742 116+3 cam, Sheet-metal Intake, 70lb Siemens injectors, SLP, GMM Ripshifter, QA1 Coil-overs front and rear, nylon suspension bushings, Hotchkis, RPM Trans, SPEC twin clutch, SpinTech, Kooks 1 7/8 -2.0", BMR drive train, Kaaz 3.91, Lingenfelter CAI, Baer brakes, mini-tubs, E85.
GTO_Gregory is offline   Reply With Quote
Old 11-23-2021, 09:39 PM   #13
Aragorn
Drives: Camaro SS 1LE
1/2 tank.
Aragorn is offline   Reply With Quote
Old 11-23-2021, 09:50 PM   #14
Grumpy1
Grumpy1's Avatar
Don't usually go past quarter but no specific amount, sea foam with every fill up....
Grumpy1 is offline   Reply With Quote
