Old 11-21-2021, 03:28 PM   #1
Timbo-1LE
Timbo-1LE's Avatar
Drives: 2017 SS 1LE
Clutch delay valve
Has anyone played with removing the clutch delay valve under the dash? I believe mine is possibly blocked, as the clutch pressure, engagement point and overall feel is starting to be random. I have replaced the fluid and it was better this after noon, but sometimes its still seems like clutch engagement and disengagement is overly delayed, then the peddle pressure is soft initially, then a few shifts it may or may not come back.
Seems the dodge boys remove theirs on the hellcats, with positive results. Maybe I will just buy a replacement and swap it out, and see what happens.
Welcome any input.
Timbo-1LE is offline   Reply With Quote
Old 01-12-2025, 11:24 AM   #2
conall
conall's Avatar
Drives: 2019 Camaro V6 manual
When I was looking into an LT1 or an SS, the dealer told me there is no clutch delay valve.
80mm Overkill tb and Tune, aFe CAI
Charger R/T
conall is offline   Reply With Quote
