Old 11-19-2021, 01:36 PM   #1
AZ_SS
AZ_SS's Avatar
Drives: 2018 Camaro ZL1 M6
Sea Foam
Has anyone ran Sea Foam through the intake of their LT4? I am a kind of leery about it and I can't find any info about running it through the supercharger. Thanks.
AZ_SS is offline   Reply With Quote
Old 11-19-2021, 01:49 PM   #2
gotswap
gotswap's Avatar
Drives: 2019 ZL1 Crush
yes and no harm
2019 Crush A10
E-Force 2650
670WHP 615WTQ
All besides the 2650 is bone stock down to the air filter.
gotswap is offline   Reply With Quote
Old 11-19-2021, 02:00 PM   #3
10mm
Drives: My wife nuts...
Perhaps change the oil afterwards ??
10mm is offline   Reply With Quote
Old 11-19-2021, 03:26 PM   #4
AZ_SS
AZ_SS's Avatar
Appreciate it.
Old 11-19-2021, 03:47 PM   #5
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
I’ve used the crc intake valve cleaner twice with no I’ll effects. It doesn’t contain anything that would harm the blower.
Does seem to do a decent job at cleaning some gunk off valves.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 11-19-2021, 03:50 PM   #6
SJFGTO
Oh Oh it's Friday Night!
SJFGTO's Avatar
Drives: 2018 ZL1 1LE Nightfall Gray
Sea foam has been around forever. It was very popular back in the LS2 days of the early 2000s. Never heard of it doing any harm.
Four that wanna own me
Two that wanna stone me
One says she's a friend of mine...
SJFGTO is offline   Reply With Quote
Old 11-19-2021, 05:09 PM   #7
AZ_SS
AZ_SS's Avatar
I was just concerned about it pooling in the blower.
Old 11-20-2021, 04:22 PM   #8
Grumpy1
Grumpy1's Avatar
Used Since my first tank of gas....no issues.
Grumpy1 is offline   Reply With Quote
Old 11-20-2021, 05:35 PM   #9
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
He’s talking about spraying it into the intake to clean the valves , not putting it in gas.
CRC is still the better option as it contains high levels of PEA.
Old 11-20-2021, 06:37 PM   #10
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Agreed.
Old 11-21-2021, 12:25 PM   #11
jvandy50
Drives: 18 ZL1-1LE, 10 JKU
talked me into it. We were surprised at all the gunk at 11k miles during my cam install. This was the exact product we were looking at
jvandy50 is offline   Reply With Quote
Old 07-13-2022, 11:04 PM   #12
Need4Camaro
Drives: '17 Camaro 2SS & '99 Camaro Z28
I couldn't get my hands on CRC cleaner locally. None in stock here anywhere so I ended up going with Seafoam.
I didn't want to do this in my neighborhood so I went to a QuickTrip near the toll road so I could immediately open it up when I was done, except.. ..there was a cop there.. ..so I waited for the cop to leave and I began..
I managed to undo the Brake Booster with the motor running. Surprisingly it did not idle high at all with the brake booster disconnected. I also noticed my Brake Booster seemed very oily.
I slowly poured it in with the motor running, no smoke came out initially. The motor also would not stall when I poured it in despite being instructed to intentionally stall it with the seafoam. When I finished up, I reconnected the Brake Booster, I let it sit for about 15 minutes. It was a very rough crank to get her back to life. She idled okay up to the tollroad, but when I stepped on it, it felt like I was revving in nuetral for a moment and pure soot just exploded from my exhaust.. ..it bucked for a bit and the check engine light started flashing as I rolled onto the tollway.. .. onto the ramp I opened it up WOT.. ..getting it to about 80 where I just left clouds of smoke behind me, backing out of it as I merged onto the highway.. .. .. where I slowed down to about 50 MPH and prepared for another WOT run.. ..but that was interrupted as I ran across two sheriffs in the median of the highway.. ..and I just innocently cruised on by them at 25 MPH BELOW the speed limit ... I waited about a mile or so and then gassed on it again, this time throttle response was much sharper.. ..but not wanting to press my luck, I got off the tollway a few exits down.. ..1st Gear response was no longer sluggish, no bucking or rough idle.. ..so now we just wait and see until the next few cold starts to see if this helped my problem. (My car was randomly misfiring during cold start idles)
Need4Camaro is offline   Reply With Quote
Old 07-14-2022, 08:12 AM   #13
Wuiquen
Wuiquen's Avatar
Drives: 2018 Hot Red ZL1
Why the brake booster? would it be better to do it at the TB elbow? Ive been meaning to do this for my cars but I always get worried about it. Also, I think my neighbors will probably call the fire department.
Old 07-14-2022, 09:22 AM   #14
Need4Camaro
Not sure for the TB Elbow. I've always done it through the Brake Booster. When I do it, I don't do it in my neighborhood. I go someplace out in the open where I can quickly open it up, and also not remain in one place very long in the event someone gets peeved.
