Car Covers
Looking for a car cover that won't cost an arm and a leg to cover my ZL1 while it is parked under an enclosed Carport so nothing real fancy is needed.
The one I had for the Corvette is too small! Thanks!
2022 Black ZL1
RotoFab CAI, AWE Touring Edition Cat Back Exhaust. 665 Crank hp. est. and 660 Crank ft. lbs. est. Never been Dynoed |
Geezer_loves_Camaros
Drives: 2018 2SS, Black, A8 Join Date: Dec 2018
Mine is parked in the garage a lot when not in use - it’s not a daily. I use a cheap Budge Duro. It keeps the black from getting dusty so quickly. Haven’t noticed any scratches from it but just started using it a month ago. Fwiw
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
Which ever one you decide on, just make sure the car is clean before you put it on.
#4 | |
![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL1 Join Date: Mar 2019
After that I switched to a Noah block it cover which of course was more but it’s held up Great over a year now to the baking sun and elements. My car stays outside until garaged in storage in winter. Most cheap if not all covers are also not pre fit. The more expensive ones are. My Noah is a prefit cover. Check out https://www.covercraft.com/us/en/ They have a lot of nice covers.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Aug 2013
![]() Drives: Camaro 6 Join Date: Jul 2022
Hi there, mate. Actually, I have my car parked in the carport, so I have nothing to advise you. But you know, tbh, I used to have a cover until my friend from https://carportaustralia.com.au/colorbond-carport/ built me a carport. You know, I guess I found the cover for my Camaro somewhere on Amazon. Tbh, I just can’t remember, but I guess you can find it there without any difficulties. Btw, why do you really need it? If you don’t often go for trips by car, a carport is what you need. Anyway, keep us updated.
