Old 11-17-2021, 01:56 PM   #1
Coded4SS
Drives: 23 Zl1
1le Not Covered under Warranty for Track Use
Hi All,
Long story short my car is eating throw out bearings every few hundred miles. The dealer says since its been on the track GM will void the warranty. (they made this assumption based on my tire wear, dust imprint on my drivers side door).
They basically position themselves this way to keep me from getting my car fixed, but i have it word for word.
So is that it? The 1le track package is not covered under track use?
I read the articles about motor trend and etc, but i have yet to see anything official in the warranty documentation.
Coded4SS is offline   Reply With Quote
Old 11-17-2021, 02:07 PM   #2
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
yes it is i would go to another dealership what place u going to?
Old 11-17-2021, 02:08 PM   #3
joeyazzata29
j1ss
Drives: '21 2SS 1LE
Originally Posted by Coded4SS View Post
Hi All,
Yes, it is covered under track warranty, start a case with GM or try a different dealer - that is messed up.
Racing is not covered under warranty, but non competitive track driving is
https://www.roadandtrack.com/new-car...-to-the-track/
joeyazzata29 is offline   Reply With Quote
Old 11-17-2021, 02:09 PM   #4
Coded4SS
Drives: 23 Zl1
simpson in irvine. They have been nothing but a headache the entire way
Old 11-17-2021, 02:10 PM   #5
Coded4SS
Drives: 23 Zl1
so thats encouraging.
Literally in the high performance manual:
"Track events or competitive driving
may affect the vehicle warranty. See
the warranty manual before using
the vehicle for racing or other competitive driving"
Old 11-17-2021, 02:12 PM   #6
joeyazzata29
j1ss
Drives: '21 2SS 1LE
I had issues on track that were covered under warranty, ive had friends blow engines on track covered under warranty, def open a case with GM or visit a different dealership
Old 11-17-2021, 02:20 PM   #7
kropscamaro16
haha my buddy family owns them i got a used car from them in garden grove never had any issues but never had any work done by them i go to dellilo in hb always been good to me
Old 11-17-2021, 02:22 PM   #8
JKSully
JKSully's Avatar
Drives: 22 Camaro 2SS, 20 Subaru Crosstrek
So out of curiosity - who's on the hook for proving that a trip to the track was or was not a competitive event? Does GM have to prove it was for more than just timed-lap fun? Or does the owner have to prove that there was no competition/prizes?
Either way, to the OP - as others have said - go talk to another dealer and explain what the car is doing. Leave out the part about Simpletons refusing to repair under warranty and just see what the other dealer says.
Also - what do you mean by "dust imprint on the door"?
Earth is an oblate spheroid
2022 | 2SS | M6 | NPP | Summit White | Carbon Flash Wheels | Black Lugs | Red Calipers | Adrenaline Red | Red Knee Pads | Nav |
- 1100 - 8/16/21
- 3000 - 9/21/21 - TPW 10/18/21
- 3400 - 10/1/21
- 3800 - 10/20/21 - built 10/19/21
- 5000 - 11/12/21
- 6000 - 11/13/21
JKSully is offline   Reply With Quote
Old 11-17-2021, 02:23 PM   #9
Coded4SS
Drives: 23 Zl1
Ill try dellilo out. Thanks.
I have a lot of held back words for Simpsons service right now
Old 11-17-2021, 02:25 PM   #10
Coded4SS
Drives: 23 Zl1
Thanks man will do.
Basically if someone were to track there car they would have a vinly # on the drivers door. If the car wasnt washed and the sticker removed, it would show a clean section. I swear. .....
Old 11-17-2021, 02:33 PM   #11
JKSully
JKSully's Avatar
Thanks man will do.
Ah, now it makes sense - but it still doesn't prove jack about whether it was non-competitive or competitive. Hell, you could have had a magnetic advertisement stuck on there for all they know. But still, maybe wash the car before you take it to the next dealer, or hit it with quick detailer and a microfiber
- 1100 - 8/16/21
- 3400 - 10/1/21
- 5000 - 11/12/21
- 6000 - 11/13/21
Old 11-17-2021, 02:36 PM   #12
m6-lt1
m6-lt1's Avatar
Drives: 2023 Chevrolet Camaro 2SS 1LE
Think I saw your video about this on YouTube. Here’s the thing, I think throw out bearings are considered a wear item so it may be difficult to get it replaced (and I’ll add replaced a second time) under warranty regardless of whether or not you tracked the car. Now I do agree that yours seems to be failing because there is something causing it to fail versus failing from wear. I could be wrong about this but I think our cars use the same reservoir for the brake and clutch fluid. Maybe try to see first if you have a leak following the brake fluid line that goes to your trans or any of the brakes. If you find something than I think you have a case that something failed causing your first and second throw out bearings to fail and GM failed to fix it the first time.
m6-lt1 is offline   Reply With Quote
Old 11-17-2021, 04:26 PM   #13
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
Drives: 2018 ZL1 1LE
Who have you been dealing with over there as far as Service Writer, Mechanic and Manager?
Old 11-17-2021, 04:47 PM   #14
Coded4SS
Drives: 23 Zl1
Service manager primarily. I have talked about this with their manager previously and the time line goes back and fourth. Going to call service manager today to discuss this more.
