Old 01-09-2010, 10:18 AM   #1
CamaroFemme
CamaroFemme's Avatar
Drives: 2010 Black Camaro 2SS/RS
How cold does it have to be before the pipes burst?
I'm in the southeast corner of Oklahoma, and it's freakin' colder than usual here. I left a tap running a very light stream of hot water last night, but I was just wondering (since it so rarely comes up here): what temperature should I start doing this?
CF
My boyfriend don't mind it.
CamaroFemme is offline   Reply With Quote
Old 01-09-2010, 10:20 AM   #2
rodimus prime
Drives: Cargo van.
I would say in the teens. As long as you dont have any exposed to that temp they should be okay. But it doesnt hurt to leave a faucet dripping. Mine busted last year because I left my garage door open over night. When they thawed my garage was a mad water fest.
rodimus prime is offline   Reply With Quote
Old 01-09-2010, 11:57 AM   #3
mfr1950
mfr1950's Avatar
Drives: 2011 challengerR/T , 2010 Ram R/T
I leave a little water running when it drops to 12-15 degrees,How well is your house insulated??
mfr1950 is offline   Reply With Quote
Old 01-09-2010, 12:38 PM   #4
drtwo
drtwo's Avatar
Drives: 2SS RS Yellow, Raptor, Vrod
Depends in theory if the pipes are exposed to the outside air it may only take upper twenties to freeze the water inside. The higher the pressure in the pipe will add a little protection, but not much. I'd say just take your fingers and put them up to your teeth and chew...and pray they don't bust as it is quite a pain to fix in the cold.
I'm sure you will be fine as most homes (other than moble homes) are pretty well insulated even in the crawl space.
2SS RS Rally Yellow, LS3, M6, sunroof, extra on the fast!
drtwo is offline   Reply With Quote
Old 01-09-2010, 12:46 PM   #5
pastohio
Drives: Indy Pace Car
Seems that public schools taught me water freezes at 32 degrees, now throw in all the other crap, outside, in the walls, or whatever....
pastohio is offline   Reply With Quote
Old 01-09-2010, 01:15 PM   #6
MONTANACARGUY
Drives: CHEV TAHOE CHEV IMPALA 69' COUGAR
It was 23 below zero here on monday...no frozen pipes ever. I think you are supposed to let the cold water run a little bit to help it to not freeze, not the hot.
you may not have the same insulation level we have here in Montana so I would think anytime it's gonna get to 32 or lower you might want to leave it run.
MONTANACARGUY is offline   Reply With Quote
Old 01-09-2010, 01:25 PM   #7
meanmike
Drives: FIRST ON RACE DAY
For those in the south it might be different but you should'nt have to leave your water running if your home is heated and insulated. I own to home's one in Maine and one in Indiana and the water is never left running.
meanmike is offline   Reply With Quote
Old 01-09-2010, 02:42 PM   #8
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
CF
Depends. Are you on city water or do you have a well? If you have a well, you will want to anytime it drops below freezing to prevent the water pump from freezing as these pipes are exposed to the cold. If you get your water from the city then you only need to do this if the pipes are exposed outside or if you pipes are not buried below the frost line of your area.
Mr_Draco is offline   Reply With Quote
Old 01-09-2010, 08:22 PM   #9
springerpete
Orange GM freak
springerpete's Avatar
Drives: 2004 3500HD
He's right leave the cold water on. Just make it a very light drip. The water only has to move to keep it from freezing. I live in Ponca and it's supposed to be down below zero tonite.
"My hair's turnin' White, my neck is still Red and my collar is still Blue"
springerpete is offline   Reply With Quote
Old 01-09-2010, 09:15 PM   #10
skuttduck
skuttduck's Avatar
Drives: 2010 RJT 2LT Camaro
Send a message via ICQ to skuttduck Send a message via AIM to skuttduck Send a message via Yahoo to skuttduck
I can barely remember having any pipes freeze in the houses we grew up in.
I believe the only issue that you would have with that is if your pipes run in an area where it is uninsulated.
I believe as long as you get normal use you would be fine. I also kind of wondered about the outside taps for the hose, but it's been -18 here and I've not had an issue.
You could always insulate your pipes that will help to. It's nice to do it to the hot water and notice that it doesn't take as long for that water to get up to heat when you run a shower.
skuttduck is offline   Reply With Quote
Old 01-10-2010, 02:03 PM   #11
CamaroFemme
I'm in the countryside but have city water. The only exposed pipe I have is outside where the garden hose links up. It's actually funny (..kinda) because a few hours after I posted the original question, that pipe burst! But it was no big deal, it didn't run long, and my uncle fixed it. I just have no way to wash the car at home now (not a tremendous loss)
Old 01-10-2010, 02:09 PM   #12
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
+1. I've been in Buffalo here for my entire life...we've never left our water running in the winter. Negative temperatures are common here...yesterday it was 2.
In fact...and I'm surprised at myself...I've never even heard of this before now!
Old 01-10-2010, 05:07 PM   #13
Iroczlover
The Krazzy bytch
Drives: Which car I have 9 vehicles?
Send a message via MSN to Iroczlover Send a message via Yahoo to Iroczlover
just about a month ago we had temps freezing, staying in the 20s if not teens at night & warming up to maybe 30 if we were lucky, we had several people pipes burst but not ours (knock on wood) Ours are exposed but I just let the cold water run during the night when I went to bed.
on the car washing thing you shouldnt wash your car during times where Its suppose to be drop down to freezing or below because it can shatter the windshield (or at least Thats what I tell people at work to prevent to having to wash my van during the winter months Lol)
Iroczlover is offline   Reply With Quote
NEW PRODUCT! K&N Typhoon Cold Air Intakes!!! MoranoRacing V8 Bolt-Ons & Tunes 2 12-28-2009 11:39 AM
Straight Pipes and CAI. SharpSS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 4 12-17-2009 04:46 PM
COLD COLD COLD Iroczlover Off-topic Discussions 41 12-10-2009 08:15 PM
Squeaking/Whistle noise on driver side of engine on cold start shiftz33 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 4 08-23-2009 04:22 PM
V6 Camaro STRAIT PIPES VIDEO will be Posted Tomorrow!!!! derin11 5th Gen Camaro SS LS LT General Discussions 2 06-07-2009 04:04 PM
